				stuck mk1 door lock
Thu, 09 Jan 2014 12:04 +0000by fez
				So recent I've been having to get in and out of the car by taking the roof down and climbing in.
Door lock is stuck in the locked position. The key turns most of the way, but the lock seems to stop in the last few degrees of turning. Can't unlock the door from the inside, the lock doesn't slide far enough.
It has happened before and it fixed itself while I was driving.
Has anyone any ideas about how I can fix it or will it mean that I'll need to change the locks? (ignition lock is different key anyway so its not that big a deal)
				Re: stuck mk1 door lock
Thu, 09 Jan 2014 12:44 +0000by scallan
				Did u try oiling it??
Thu, 09 Jan 2014 1:40 +0000by Steve
				I've had something similar in the past, check out this thread :
viewtopic.php?f=12&t=3458&p=29912&hilit=lock+spring#p29912
Thu, 09 Jan 2014 8:12 +0000by MX5Spares
				There is a small spring in the lock that snaps off sometimes and get jammed but you need to get door trim panel off the inside to see it .Awkward.
Thu, 09 Jan 2014 10:57 +0000by Steve
				Yep, that's exactly it. I think I remember using a spring from a biro to get me by until I sourced a proper part.
This is where the spring is :
Thu, 09 Jan 2014 2:18 +0000by fez
				cheers steve, Is that photo above right at the close of the door? I think my car is falling apart enough to take the door panel off with the door closed.
Thu, 09 Jan 2014 6:04 +0000by Steve
				the camera is in the door pointing towards the rear, halfway up the door.
Thu, 09 Jan 2014 11:22 +0000by 93 Mk1
				I just done this a few weeks ago. What a difference ! The spring from MX5 Parts UK is supposed to be an ungraded part
 so should be more durable than the original. Mind you, the originals are around 20 years old now....
Sun, 19 Jan 2014 7:39 +0000by fez
				So took the door card off and everything was in its right place. Drowned it in wd40 wiggled it and the door opened!
No more dukes of hazard entries for the moment!
Fri, 14 Feb 2014 4:41 +0000by fez
				It happened again, while the car is up with autocheck...
Sat, 15 Feb 2014 2:26 +0000by 93 Mk1
				Did you check that spring on the door handle ?
Sat, 15 Feb 2014 8:40 +0000by fez
				Yep. Still there.
Fixed itself again. Might be due to lack of use!
