Im back
Im back
Postby sidewaysreilly » Mon, 30 Jun 2014 10:26 +0000
Im back , to help criticise and annoy !
Re: Im back
Postby leamyj » Tue, 01 Jul 2014 6:51 +0000
Didn't even know you were away!!
Re: Im back
Postby Oregato » Tue, 01 Jul 2014 8:37 +0000
Welcome back, I'm back too (although I normally lurk in the background anyway). Picked up a MKII RS last week and had a few bits done by Robert over the past few days - top bloke!
I'll start a thread at some stage
Oregato
Re: Im back
Postby Steve » Tue, 01 Jul 2014 11:09 +0000
sidewaysreilly wrote:Im back , to help criticise and annoy !
Welcome back, thought you were lost at sea or something
Re: Im back
Postby sidewaysreilly » Tue, 01 Jul 2014 8:35 +0000
Yeah adrift and castaway lol
Re: Im back
Postby rhysmate » Wed, 02 Jul 2014 2:20 +0000
Turbo yet?
Re: Im back
Postby sidewaysreilly » Wed, 02 Jul 2014 6:55 +0000
Yeah was up and running good . Decided to go with charge cooler but a weld failed and the engine hyd locked bending a rod . So all stripped and took the oportunity to put a recon front subframe in . Still at that stage as time at a premium . Will be interesting tho.
spec is charge cooled RS mk2 engine @ 9.5 comp ratio on link ecu .
Turbo is td04hl 16t on custom manifold and exhaust . Turbo has a built in dump valve which is handy .
Hop to get it finished soon but tine is limited.
Re: Im back
Postby barney » Wed, 02 Jul 2014 9:13 +0000
Long time no hear Sean, that's the problem with your job. No engine's big enough or powerful enough :D :D
Re: Im back
Postby sidewaysreilly » Wed, 02 Jul 2014 10:30 +0000
Your r ight Brian , all aftercoolers and no intercoolers !
Re: Im back
Postby rhysmate » Thu, 03 Jul 2014 10:12 +0000
sidewaysreilly wrote:Yeah was up and running good . Decided to go with charge cooler but a weld failed and the engine hyd locked bending a rod . So all stripped and took the oportunity to put a recon front subframe in . Still at that stage as time at a premium . Will be interesting tho.
Nice! should make lovely power! Should get a build thread going would be interested to see it
Re: Im back
Postby sidewaysreilly » Tue, 02 Sep 2014 7:31 +0000
yeah will do when I get a pc sorted.
Put in the refurbished RS front subframe and tidied up some piping. Just need the chargecooler water pump relayed and she is ready for tuning.
Re: Im back
Postby sidewaysreilly » Wed, 03 Sep 2014 12:04 +0000
Re: Im back
Postby rhysmate » Wed, 03 Sep 2014 1:15 +0000
getting there!
Re: Im back
Postby Steve » Wed, 03 Sep 2014 12:04 +0000
interesting intercooler, what is it?
Re: Im back
Postby sidewaysreilly » Wed, 03 Sep 2014 10:12 +0000
Its a charge-cooler lad, water filled. Custom made but a bit of work to plumb in the rads for it, wire the circulation pump etc. Its way over-sized for the application but will allow me to fit a much bigger turbo later on and still keep inlet temps low.
Users browsing this forum: No registered users and 24 guests
