Am i paranoid?
Am i paranoid?
Postby mx5ash » Mon, 19 May 2008 10:05 +0000
There has been so many things go wrong with my car i think i have become totally paranoid. Every noise i hear (current ones are a slight knock from somewhere (suspension???!!!!) and a whine in the engine) makes me think that the the car is about to blow up, breakdown or just go wrong.
So am i paranoid and all cars make some noise's & rattles (especaily a 16 year old one) or should i worry.
Btw it drives better than ever, no lose in power, handles well, temp seems fine, oil pressure ok.
Postby MX5Steve » Mon, 19 May 2008 10:12 +0000
I think its all in the mind,
I read on miata.net how a HLA works, I am convinced the engine wasn't ticking before this, and NOW!. I'm demented leaning forward every time I turn the key. Since the post about the glovebox here I've started hearing every single creak from the thing. :cry: but hey, just means getting to know em a bit better...... 8)
Postby mx5ash » Mon, 19 May 2008 10:19 +0000
I know the bloody car to well at this stage, i don't mind noise if i know what it is. its the ones that i cant find where they come from.
Postby sspecdave » Tue, 20 May 2008 10:16 +0000
:roll: I was in the same boat last week Ash. Had an annoying rattle coming @the front only at speed 80-100k+and after 5 evenings of looking around underneath i eventually have found it to be the front right wheel bearing which i stripped out to check. It can be so annoying when ya cant actually see the problem but eventually you'll track it down.
On the wheel bearing issue having probs finding one @ the moment as all the usual suppliers mx5parts/autolink/sumo seem to be out of stock and dont fancy paying 215 euro to mazda for one . :wink:
Postby Steve » Tue, 20 May 2008 10:30 +0000
MXV8143
Wheel Bearing Kit (Front)
£89.95
€125.92
http://www.moss-europe.com/Shop/ViewPro ... dexID=3374
Postby mx5ash » Tue, 20 May 2008 11:34 +0000
Cheers dave, might call down to you some evening and get you to have a listen and see what you reckon.
driving me nuts.
Postby Steve » Tue, 20 May 2008 11:44 +0000
heheh nothing like a good dose of Automotive Hypochondria to get you out there fixing bits ;-)
Postby sspecdave » Tue, 20 May 2008 4:54 +0000
srigley wrote:MXV8143
£89.95
€125.92
Thanks Steve.
Mx5 parts have em back in stock now so order 2 for front and 2 rear bearings also.
Might aswell do the lot since the car is 16 years old now .
Thanks again. :wink:
Postby mx5ash » Tue, 20 May 2008 9:48 +0000
I reckon that the noise is from the front right side and pretty damn sure it ain't anything to do with the suspension. Remember the hub i asked you about Dave that seems a bit loose. Would that indicate wheel bearing??
Postby Reesy » Thu, 22 May 2008 9:05 +0000
Paranoid?
Yep, me too.
I'm forever thinking that the moan in the rear wheels has got worse / the gears are getting harder to engage / one shock is f*cked, etc. etc.
This tends to happen when I'm tired & stressed or miserable... just like when I start feeling old & fat!
...or maybe I just am...
Reesy
Postby Sean » Thu, 22 May 2008 10:18 +0000
:lol:
Sean og
Sean
Paranoia?.......as we are on the subject,does any one ever feel the government might be sending subliminal messages to them through the voices of the newsreaders on the RTE1 9 o clock news? :?
Sean og
Sean
Postby MX5Steve » Thu, 22 May 2008 10:19 +0000
Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen............... :lol: :lol: :lol:
Postby Sean » Thu, 22 May 2008 11:03 +0000
coughlanstephen wrote:Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen-Must forget use of F word used by brian cowen............... :lol: :lol: :lol:
PROOF!!! :shock: They are watching us!!! Run while you can!!!
Sean og
Sean
Re: Am i paranoid?
Postby HughiusMaximus » Fri, 23 May 2008 2:52 +0000
mx5ash wrote:There has been so many things go wrong with my car i think i have become totally paranoid. Every noise i hear (current ones are a slight knock from somewhere (suspension???!!!!) and a whine in the engine) makes me think that the the car is about to blow up, breakdown or just go wrong.
I know what you mean, ever since I put in the turbo I have been worrying at every new noise coming from the engine...
Its getting to the stage now where I am going to put aside some money in case it goes pop and just drive the sh1t out it until it does.
Had a new ticking noise myself, friend who is a mechanic said that it could be the HLA's or else it could be a push - rod going in the engine (which would be game over for that engine...)
I'm just waiting for the day when it lets go in a big cloud of smoke as im try to overtake a yaris or somthing!
I suppose its the trouble of trying to get more performance out of old cars....
Burn him!! Burn him!!!
HughiusMaximus
