Does this look right
Postby Pops » Mon, 20 Mar 2017 8:08 +0000
Finally got around to getting the alignment done just over a week ago but while doing it they found a rear shock leaking pretty bad, so today I replaced the bad shock (thanks robert), however I spotted the camber bolts looking lost in the collar
left rear.the one on the right is fairly similar
Don't know if it's right or not
Re: Does this look right
Postby Real Rayzor » Mon, 20 Mar 2017 9:32 +0000
Not sure Pops but I can tell you that mine are the same.
Real Rayzor
Postby Pops » Mon, 20 Mar 2017 10:10 +0000
Thanks, probably worried about nothing so. As they say, leave well enough alone.
Postby MX5Spares » Tue, 21 Mar 2017 7:36 +0000
Hard to tell from the pics but normally the are at 12oclcok position or near enough unless you have lot camber on. or something damaged etc
Postby Pops » Tue, 21 Mar 2017 4:10 +0000
MX5Spares wrote:Hard to tell from the pics but normally the are at 12oclcok position or near enough unless you have lot camber on. or something damaged etc
That's what I thought, when I replaced all the bushings & camber bolts I set them at about 12oclock with the washers in contact with the collar but when the guy was doing the alignment I could see him turning the bolts 180 degrees, totally upside down in the collar. Trying to explain to him that it was wrong wasn't good but got within specs eventually.
Users browsing this forum: Bing [Bot] and 28 guests
