Cracked and faded rear window tint
 pretty poor looking
 trying to remove the tint was a right pain as I could only pick a tiny bit at a time
thanks to YouTube I found a way to soak the tint using a sheet of plastic liner and household cleaner, shape the plastic to fit the window, soak the tint with the cleaner (cif actifiz) and place the plastic on the glass, leave the car outside in the hot sun for 20min then peel off the plastic bringing the tint with it. As we don’t have any sun I used a heat gun , the tint didn’t come off with the plastic but it was softened enough to be able to peel it off
 where I had picked bits off the glue was left behind, tried panel wipe and thinners put still couldn’t clean the glue, as they say, never throw anything away, found a bottle of Targ graffiti remover that I got about 10 years ago, after a few minutes there’s no more glue
 bottom half removed in one piece
 done.
Now the question is , do I leave it clear or get it properly tinted
  FAQ
 FAQ
