Not as hard as it looks to remove it
Boost chamber and pipes removed, seems to be a lot of engine oil in it
Supercharger rattlesThe slk supercharger was making fairly serious rattling noises and very noticeable when cold, so as its declared off the road I thought I might try servicing it.
Not as hard as it looks to remove it ![]() ![]() Boost chamber and pipes removed, seems to be a lot of engine oil in it ![]() ![]() Sent from my ELE-L09 using Tapatalk
Re: Supercharger rattlesRemoved the snout, all looks OK
![]() 14ml of oil in the snout and it stinks something terrible ![]() Sent from my ELE-L09 using Tapatalk
Re: Supercharger rattlesIt did leak some more oil when it was dismantled so I'd say there was a max of 16ml in it, it's supposed to have 150ml
All looks good but the circular coupler has play on one side ![]() New coupler and oil, enough oil left over to be able to change it again if needed ![]() All done now and no rattles thankfully Sent from my ELE-L09 using Tapatalk
Re: Supercharger rattlesExcellent!
BTW, there is a mod to remove the internal baffle plate too if you fancy louder superchargery sounds Sent from my Redmi Note 5 using Tapatalk
Re: Supercharger rattlesHa ha, getting too old for any loud noises.
Re: Supercharger rattlesI second Steve's motion after all, it's called a supercharger, not a mediocrecharger!
Sent from my ASUS_I001DE using Tapatalk
Who is onlineUsers browsing this forum: Bing [Bot] and 23 guests | ||
