having trouble doin the rears, piston is jammed.
Grainger says it should just "tip out" pure boll***......
 Refurbishing Rear brakesanyone know of an online guide to refurbishing brakes.
 having trouble doin the rears, piston is jammed. Grainger says it should just "tip out" pure boll***......     Thanks
   This any good to you.
 http://www.miata.net/garage/brakepad.html  http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
   thanks ash. nah no good.
 I think there probably just too old, pat gave them to me when I bought the car, but I have a leak on the drivers side rear and I thought I would try and refurb one before i removed the leaking one. I think its just corroded and jammed   no bother
   I had the same issue, know way would the top pivot come apart. it was pivoting but at the end that shouldn't be if you get me. Ended up getting a refurbed one from autolink.  http://www.cardomain.com/ride/3099765 "When I make a key the on position and push the button, an engine works"
   Mx5Parts also do a refurbed/exchanged one for £75.95......
 http://www.mx5parts.co.uk/product_info. ... cts_id/380 Or just get a second hand pair from a 1.8 from SniffyDog.co.uk !
 Steve . Drop them up and we will have a go as i refurbished my front /rear ones last year with new seals and pistons and was'nt to big a job. Might need some hydraulic pressure to push out the pistons
   you did try using the adjuster thats under the bolt on the back of the caliper yeah? (only the rears have this adjuster..)
   I fixed one of mine at the strart of the week. My piston was seized too so I re-attached the caliper to the car, removed the pads and pumped the brake pedal to use the hydraulic pressure to push the pison out onto the floor.
 It was pretty corroded so I soaked it in coke overnight, gave it a good scrub with a wirebrush and it came out like new. Put it all back together with new axiss pads and bled the system - good as new!
| Who is onlineUsers browsing this forum: No registered users and 2 guests | ||
