				E10 making driving dangerous
Sun, 17 Mar 2024 10:24 +0000by SilverDoll
				Here's something I've noticed with two cars and heard about in other cars: Since the E5 petrol was replaced with E10, cars are less responsive when you need to accelerate quickly from a stop / crawl. My Mx5 is 21 years old and I now have to use additive to keep her "zippy", but still the performance is not what it used to be; she needs to stay in 2nd longer if I'm doing quick acceleration on (for example) a main road when some clown suddenly comes out a gate.
It's not just the Mx5. My mother's car is an Opel Corsa, only 11 years old and is even worse. Other people with different makes of car are reporting similar problems on roundabouts and when overtaking.
				Re: E10 making driving dangerous
Thu, 21 Mar 2024 12:28 +0000by Steve
				hmmm... I wonder if playing with the spark timing would help?
Thu, 21 Mar 2024 7:06 +0000by SilverDoll
				I don't know... Gave the car a long drive yesterday and she was like new. The car has a mind of her own at this stage.
Thu, 21 Mar 2024 7:51 +0000by Pops
				This is the stuff I use, supposed to be good and probably is as I haven't noticed much difference since the E10 fuel came out
https://onestopmotorshop.ie/product/lucas-ethanol/
Thu, 21 Mar 2024 11:05 +0000by SilverDoll
				Thanks, I am going to try that. I'm using this at the moment:
https://www.theoilstore.ie/store/E10-Fu ... p579459852  and I think the reason the car wasn't acting up yesterday was because I used about twice as much as the recommended amount. My mother didn't use it the last time she topped up her petrol (in the Corsa) and it was stalling a bit too.
Anyway, the Mx5 has another problem now: steering fluid leak and the rubber off the ball joint on the front suspension arm, also the steering rack gaiter. All these problems came up in the NCT but I recently had to top up the steering fluid and I was warned about a small leak after that (when I got a welding job done on her - finally got that rust sorted professionally).
Thu, 21 Mar 2024 11:18 +0000by Pops
				Ya, there's loads of additives available, the bardal brand has been around a long time.
NCT always find some sort of faults but a leak still needs to be fixed, ball joint rubber boots are available in most motor factors and a steering rack boot should be easy enough to get but don't get the plastic y type as they're useless
Thu, 21 Mar 2024 11:29 +0000by SilverDoll
				Reassuring to hear that they're easy to get. I won't be doing any of this work myself.
Thu, 21 Mar 2024 11:34 +0000by Pops
				The cars are great but do need repairs at times, enjoy driving it when it's done
Thu, 28 Mar 2024 5:13 +0000by notch000
				e10 is shit, my lawnmower took an age to start and ran like piss after the winter break, i drained the old fuel out. It a Honda engine and normally runs on first crank.
Fri, 29 Mar 2024 11:25 +0000by SilverDoll
				Re lawnmowers: we had that problem too. I put a drop of the additive in (Bardahl in this case) and it's been working OK since then. Not as good as it used to be though.
Tue, 02 Apr 2024 11:26 +0000by Steve
				wonder if that's why my older strimmer is acting the goat, will try a drop in it.
