TechDay part II @ Lucan, Dublin 23-May
Postby franksm » Mon, 18 May 2009 7:51 +0000
Hey folks
I didn't get to change the brake hoses on my car last Saturday, so....
Tech Day at my place in Lucan, Saturday 23-May.
Will also be fitting a piggyback ECU to Feargal's Greddy Something Something
Location is off Griffeen Ave, Lucan. Satnav coords 53.340160 -6.447640
PM me for the address if interested
Cheers,
Frank
Re: TechDay part II @ Lucan, Dublin 23-May
Postby robmx5 » Mon, 18 May 2009 8:12 +0000
Hey Frank,
If my new calipers arrive in the post by then, I might join ye, if thats alright
Robin
Postby Geese » Tue, 19 May 2009 9:21 +0000
Is there gonna be a Gazebo? :P
Actually I've to drill my sump for the turbo oil return too.
Geese
Postby franksm » Tue, 19 May 2009 9:27 +0000
Yeah Robin, come on ahead.
Geese, no friggin' gazebo this time. And no fly-away instructions. The neighbours' bouncy castle will also be bolted down.
Weather on Saturday looks okay (Friday will be wet).
What size tap do you need for the sump ? I still have one from my FMII, must search it out
Postby Geese » Tue, 19 May 2009 9:40 +0000
I should have the tap and drill etc in a box somwhere but if you have one that'd be great.
Hopefully weather will hold up
Geese
Postby ger » Wed, 20 May 2009 8:22 +0000
Geese, I have the tap from the greddy upgrade, its a 3/8 NPT (national pipe thread), quite a big fecker, you will need the larger size tap handle.
Give me a call if you need it.
Postby Geese » Wed, 20 May 2009 2:05 +0000
I've got a 1/2" hose barb and a 22mm drill bit :)
a 3/8" would be great but I'd need the correct hose barb for her.
Geese
Postby ger » Wed, 20 May 2009 3:44 +0000
I got the 3/8 hose barb from mx5mad, if they still have them in stock you are welcome to mine and you can order me another.
Postby Geese » Wed, 20 May 2009 7:40 +0000
I would but they don't take overseas orders off the web and they don't seem to answer my emails.
I had to get my bipes off BEGI in the states after 2months of trying to get it from Mx5mad I even called ya man he asked me to email "paul" of which i got one reply.
hey they don't want my cash obviously
Geese
Postby ger » Wed, 20 May 2009 7:47 +0000
Strange, i always rang them direct and dealt with Russell, got my turbo and harddog from them no probs.
You could probably make one on a lathe, i will bring the one i have out to franks on sat you can take a look.
Postby Steve » Wed, 20 May 2009 9:07 +0000
hmm... will ring them tomorrow, I've emailed them several times in the last 2 weeks with no reply too.
Postby mx5ash » Wed, 20 May 2009 9:15 +0000
Mx5mad are having a sale at the minute and are up the walls apparently.
See here
http://www.mx5nutz.com/forum/index.php? ... =30535&hl=
Postby Decay » Thu, 21 May 2009 12:13 +0000
After all the "hard" pre-NCT work I did at Frank's last weekend, the car passed no bother this morning :D Damn thing hadn't been tested in 6 years but everything was well within the limits. Interesting things for anyone facing theirs:
1. Car is a 93 so AFAIK it's meant to have a cat - it doesn't
2. Front plate is a sticky with proper lettering etc and no comment on it even though technically it's not thick enough, supposed to be 2.5mm
Dave
Decay
Postby fabfiveferg » Thu, 21 May 2009 1:36 +0000
Which test center were you in Dave?
Postby Decay » Thu, 21 May 2009 1:44 +0000
Feargal, it was Ballymun, they were mad busy.
Decay
