I have removed this from my 5, you will see from my other post I was not able to fit the replacement mast to it. I now have Halfords rear roof aerial fitted.
I was not able to get the drive cable on the mast to wrap round far enough on the big wheel inside before it would be trapped on the little gaps around the big wheel. To be honest I didn't try too hard.
The motor is working and the clogs inside are turning, but you may need to mess with it a bit to get the mast drive cable to wind on correctly, I can't be bothered with it and have removed it.
If someone want to make me an offer on it. I am also listing it on ebay.
No returns if you can't get the cable on as I couldn't.
