ecu units wanted
ecu units wanted
Postby jayryan » Thu, 10 Jun 2010 12:30 +0000
Hi does anybody out there have two ecu units for a mx5 mk1 1.6 manual.My car has been in the garage for the past 2 and a half months and its blowing ecu's :(
jayryan
Re: ecu units wanted
Postby sabik » Thu, 10 Jun 2010 1:30 +0000
Ow... Had a jeep with the same problem took me a year to find one.. was not impressed... BUT, out of bad things I'm now the happy owner of a mk2 mx5 so something good came out of my problem.
But think you should be able to find something to suit I'm sure pretty soon.
Glen
sabik
Postby leamyj » Thu, 10 Jun 2010 1:56 +0000
Why two??
Postby jayryan » Thu, 10 Jun 2010 4:41 +0000
my car has burnt out two of them actully its burnt three of them!!
jayryan
Postby leamyj » Thu, 10 Jun 2010 6:05 +0000
Jay, you may have seen that my car has been scrapped after an incident on the run last Monday. If you're interested in a complete re-wiring ( assuming it's a mk1 you have) I could see about taking the loom out. It could be an alternative to constantly blowing ecu's. Have you had the alternator checked? does the car have a voltage regulator or such like??
John.
Postby Sizlack77 » Fri, 11 Jun 2010 8:26 +0000
got one for AN mx5 I think interested ?
Sizlack77
Postby leamyj » Sat, 12 Jun 2010 9:43 +0000
Can anyone else add to this thread as to why jayryan's car is cooking his ecu's?? Would faulty sensors cause this? If it was to be put on a mazda diagnostic computer will they find the problem?? Has anyone here got the software /hardware to read the codes??
Will re-wiring it make a difference? If some sensor is knackered and causing the problem then re-wiring is not necessarily gonna solve it.
Postby leamyj » Sat, 12 Jun 2010 9:44 +0000
Sizlack77 wrote:got one for AN mx5 I think interested ?
I reckon he needs to find out why the car is frying the ecu first, he's already gone through several of them
Postby charged_rs » Sun, 13 Jun 2010 11:07 +0000
probably a bolloxed alternator diode...try a new alternator frst before anymore ecus
Postby Sizlack77 » Tue, 15 Jun 2010 3:59 +0000
well I know my parts are good and if you find out what causing your problem get back to me, if you want to buy ? Later
Sizlack77
