Quarter Tank Problem
Postby pjmazda » Fri, 04 May 2012 3:03 +0000
Hi Guys,
98 MKII Eunos Roadster starts miss firing when fuel gauge drops slightly below quarter tank level.
Fill it back up and goes perfectly again until next time it drops below quarter tank level.
Happens every time without fail. Didn't always do this only started doing this about 6 months ago.
I don't believe the gauge is reading high, so for some reason when the tank level falls to quarter fuel starvation kicks in.
Any clues? Anyone else see this one before?
Thanks in advance,
P.J.
pjmazda
Re: Quarter Tank Problem
Postby sidewaysreilly » Fri, 04 May 2012 5:47 +0000
is there a tank breather ???
Postby pjmazda » Fri, 04 May 2012 10:50 +0000
I'm guessing so...its standard setup..no mods to fuel tank setup here.
P.j.
pjmazda
Postby sidewaysreilly » Sat, 05 May 2012 2:05 +0000
just wondering is a breather pipe blocked. Next time it does it, open the filler and try it again.
Postby pjmazda » Sat, 05 May 2012 8:22 +0000
Thanks for this, I'll give it a try.
pjmazda
Postby pjmazda » Sat, 20 Apr 2013 11:21 +0000
Replaced fuel pump and filter and problem disappeared.
pjmazda
