Coolant leak
Re: Coolant leak
Postby charged_rs » Sun, 24 Jun 2012 12:23 +0000
major service kit
waterpump and 2 gaskets and o-ring
timing belt
cam oil seals
crank oil seal
cam cover gasket
fresh coolant (HOAT, silicate free-usually pink)
PAS and alt belt
rad cap and thermostat
job done
change the oil while you are there
Re: Coolant leak
Postby graham » Mon, 25 Jun 2012 12:28 +0000
That seems a bit excessive, I've changed the thermostat, cam cover gasket and housing and timing belt in the last 5-10km.
Whats the minimum I need? I have a spare timing belt so I dont need to purchase that, is this all I need?
G
graham
Re: Coolant leak
Postby sidewaysreilly » Tue, 26 Jun 2012 7:26 +0000
i would say that should do ya yeah.
Return to Leaks
