hard to change gear =/
Postby james » Fri, 26 Oct 2012 10:02 +0000
when my 5 is cold it is hard to change 1st - 2nd and sometimes 3rd
i am just after draning and replacing all the old fluid with brand new stuff
i also dissassembled both cylinders
the slave is 6.5/10 and i will replace it
it hard to get into and some time out of first
second gear is just plain hard to get into
i have replaced the oil in the box and diff
valvoline is what i used
do any of you people get this problem and have you got any ideas as to what the fault is ?
james
Re: hard to change gear =/
Postby rhysmate » Fri, 26 Oct 2012 10:15 +0000
Its normal enough
I get it in the mx5 nd the s2k. Once the oil is warm it gets around the box and the gears get all lubed up.. its not an issue As long as you arent grinding.
Also, if the slave is leaky itll cause trouble too so change it.. get it off autolinkuk.co.uk
rhysmate
Postby james » Fri, 26 Oct 2012 10:20 +0000
yes i see there deal is grate
id love to belive its normal but how come this is the first car that i have had this issue ( 1 starlet 2 civic's) ?
james
Postby MX5Spares » Sat, 27 Oct 2012 9:03 +0000
possibly slight wear in the bearings in the gearbox causing the gear shafts to drop slightly.Usually happens around 100k but sooner if car is being driven hard.A lot of Nissans etc seem to be the same.Gearbox is only around 150e from us so dont worry about it .!!
Postby james » Sat, 27 Oct 2012 10:37 +0000
the previous owners ware number 1 a girl and number 2 a mechanic that drove the car very very very rarely
james
james
Postby aquarian5 » Sat, 27 Oct 2012 2:55 +0000
Sounds very like the slave cylinder is on its last legs.
Postby james » Sat, 27 Oct 2012 3:18 +0000
it nose dont it
james
Postby pjmazda » Sat, 27 Oct 2012 8:01 +0000
Sounds like slave cylinder mine got so bad could not get gear at all
Pull back rubber on slave and see does any oil drop out, if it does replace slave or rubber inside slave.
pjmazda
Postby james » Sat, 27 Oct 2012 9:19 +0000
Why replace the seals when the cylinder could be scored from ware
i found a cylinder on bay for like E35 delivered
i am reading that it could be to do with the gear oil
gl5 is what i used but gl4 seems to getting good words ??
james
Postby rhysmate » Sun, 28 Oct 2012 11:10 +0000
You're over thinking it. Just change the slave cylinder...You should be OK then.. :-)
rhysmate
Postby james » Sun, 28 Oct 2012 11:14 +0000
i will but the gl4 is being highly recomended so im going with that first
james
Postby leamyj » Sun, 28 Oct 2012 8:46 +0000
Slave cylinder.......cheap and easy fix
Postby rhysmate » Tue, 30 Oct 2012 9:02 +0000
james wrote:i will but the gl4 is being highly recomended so im going with that first
it wont make any difference, its cheaper to change the cylinder and its definitely your problem man!!!
rhysmate
Postby MX5Spares » Tue, 30 Oct 2012 10:30 +0000
some people just dont listen......
