To say its driving me mad would be an understatement.
Thanks in advance
Where does this plug go??![]() ![]() ![]() To say its driving me mad would be an understatement. Thanks in advance The best way forward is sideways
Re: Where does this plug go??Don't worry about it.., when they make the wiring looms they usually incorporate all options, so it could be for something that you don't have..aircon? abs? etc.,
![]() Re: Where does this plug go??I was sort of thinking that alright but what put me off was I had an oil leak back there and everything was filthy yet the inside of that plug is spotless so it lead me to believ it was actually plugged in but its possible it wasn't.
Re: Where does this plug go??thats for the oxygen sensor...4 pin on a 1.8 mk1
take a look down by the exhaust manifold and on the down pipe you should see the sensor...feel around for the wire and connect it back up
Re: Where does this plug go??cheers, so there is a wire hanging somewhere, that makes a bit of sense, will have a look tomorrow.
yep, while its disconnected you will be getting lousy mpg
Well spotted there Paul, ![]()
![]() Re: Where does this plug go??Fount it anyway, cheers. May start another thread about a very strange whirring/glug glug noise I seem to have
glug glug noise is usually heard after a run once you switch the engine off - new rad cap will sort it
Re: Where does this plug go??Its from the back of the rocker cover and on tick over
![]() The best way forward is sideways
Re: Where does this plug go??air bubble at the back of the head or in the heater matrix? Is your heater blowing hot all the time when set to hot?
![]() Re: Where does this plug go??I changed the coolant pipe there, so might it be something to do with that? It is blowing hot air constant though.
Re: Where does this plug go??Aha! Its where I'd start anywho.
![]() Re: Where does this plug go??What exactly should I be doing though, how exactly will I go about it?
Re: Where does this plug go??Take off the rad cap, make sure the car is on level ground (or nose slightly uphill), start car and let it idle until it gets to normal temp.
If this doesn't work, I'd replace the rad cap next.
