NCT - Emissions
NCT - Emissions
Postby jproneill » Fri, 15 Feb 2013 2:10 +0000
Seeking some advice or help .
Recently bought my first MX5 – JDM (Mk2) Spec bought from a sport car specialist dealer in outside Manchester in the UK. Have to admit it may have been love at first sight.
Car went in for NCT last Saturday and failed on top Item :
1) Handbrake imbalance ( New Cable ordered to sort )
2) Emissions ( Were up at 0.7)
Have anyone experienced this before . Car has just been serviced prior to NCT .
1) Is it worth while replace Lambda sensor or will this have any effect .
2) Or take the tradition approach – Hot engine and put a couple of cleaners through it .
Any help appreciated :)
jproneill
Re: NCT - Emissions
Postby hoopsbhoy » Fri, 15 Feb 2013 8:44 +0000
Best bet is to post up all the exact readings to give people a better idea. I have failed emissions on literally everything at some point or another since the nct came in.
hoopsbhoy
Re: NCT - Emissions
Postby MX5Spares » Sat, 16 Feb 2013 10:57 +0000
Inbalance is most likely seized caliper not really cable. Emissions is probably either airflow meter or maybe throttle body.we have all parts if you need them but get it checked out first.Robert 086 8226506
Re: NCT - Emissions
Postby sidewaysreilly » Tue, 19 Feb 2013 12:43 +0000
post exact results and we can tell whats wrong.
Re: NCT - Emissions
Postby jproneill » Tue, 19 Feb 2013 1:42 +0000
Thanks Guys - Will post Exact Results this evening
jproneill
Re: NCT - Emissions
Postby jproneill » Mon, 25 Feb 2013 10:47 +0000
Results :
Lamdba: 1.00 - Not between 0.97 and 1.03
CO 0.52% VOL - Allowed 0.30%
HC 46ppm - above 200ppm
Thanks again for help .
jproneill
Re: NCT - Emissions
Postby leamyj » Mon, 25 Feb 2013 3:29 +0000
Lambda sensor is within range if I'm reading it correctly??
Re: NCT - Emissions
Postby jproneill » Mon, 25 Feb 2013 4:19 +0000
No its out too - NCT Cert says Not between 0.97 and 1.03 - Mine read at 1.00
jproneill
Re: NCT - Emissions
Postby leamyj » Mon, 25 Feb 2013 7:37 +0000
jproneill wrote:No its out too - NCT Cert says Not between 0.97 and 1.03 - Mine read at 1.00
Now I'm confused..in my reading of this, your reading of 1.00 is EXACTLY midway between 0.97 and 1.30??? What am I missing here?? :shock:
Re: NCT - Emissions
Postby hoopsbhoy » Mon, 25 Feb 2013 7:50 +0000
Lambda is a fail if is NOT between those figures, so yours is spot on.
Have you got your timing advanced?
hoopsbhoy
Re: NCT - Emissions
Postby sidewaysreilly » Tue, 26 Feb 2013 2:52 +0000
Engine is running rich, replace air filter and/or oxygen sensor.
Give it a good hard drive to burn off excess carbon and see will it pass. If not, o2 sensor or a bunged up cat.
Re: NCT - Emissions
Postby jproneill » Tue, 26 Feb 2013 12:40 +0000
Cheers for the advice
Car has just been servived - so air filter is a Brand new .
Just looking at the internet at the Oxygen sensor on the net and there seems to be literally hundreds of different Types.
Is there one in particular I should get - would a secound hand one do the trick ... ?
jproneill
Re: NCT - Emissions
Postby sidewaysreilly » Tue, 26 Feb 2013 1:47 +0000
You will need the correct one for your engine. Check out mx5parts for one.
Re: NCT - Emissions
Postby jproneill » Fri, 11 Oct 2013 4:19 +0000
Bit late on updating this Post - Problem was the CAT - If it helps aanyone else
jproneill
Re: NCT - Emissions
Postby Merlot man » Sun, 13 Oct 2013 8:46 +0000
Try Robert in Dublin for a good second hand one , his no will be in the for sale secton
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
