Fitting coilovers/shocks advice
Postby hoopsbhoy » Wed, 24 Apr 2013 7:02 +0000
Going to try finish off the car the weekend so the coilovers will be going in.
Is there any witchcraft type info I need before I do them? I keep reading stuff about long bolt methods and removing this and that. Will they really not just slide out? Mostly used to dealing with s body's and just pull the whole strut and put new one back in.
I want to use the top mounts so is there any particular way to go about it? and no I will not use spring clamps :-) Just because I refuse to buy expensive ones and I have had cheap ones split on me previously.
So eh go with the info please :-)
Edit to make more sense. Will be doing two cars the weekend, one will be changing top mounts and one will not be :-)
hoopsbhoy
Re: Fitting coilovers/shocks advice
Postby rhysmate » Wed, 24 Apr 2013 7:16 +0000
hoopsbhoy wrote:Going to try finish off the car the weekend so the coilovers will be going in.
So eh go with the nfo please :-)
They both have standard suspension in em?
rhysmate
Postby charged_rs » Wed, 24 Apr 2013 7:19 +0000
hoopsbhoy wrote: and no I will not use spring clamps :-)
goodluck with that
Postby hoopsbhoy » Wed, 24 Apr 2013 7:31 +0000
Both currently have standard suspension yup.
hoopsbhoy
Postby rhysmate » Wed, 24 Apr 2013 7:56 +0000
You'll need compressors man. you wont get them out other wise. you wont need compressors for the coilovers though.. they're small enough to squeeze in. on the back if you unbolt the top arm and the roll bar drop link you can drop the bottom arm and they pop out no bother!
rhysmate
Postby hoopsbhoy » Wed, 24 Apr 2013 8:15 +0000
rhysmate wrote:You'll need compressors man. you wont get them out other wise. you wont need compressors for the coilovers though.. they're small enough to squeeze in. on the back if you unbolt the top arm and the roll bar drop link you can drop the bottom arm and they pop out no bother!
A right so its that they actually won't fit out because you need them shorter while they are on the car?
hoopsbhoy
Postby rhysmate » Wed, 24 Apr 2013 8:21 +0000
ya they're alot longer than the coilovers
rhysmate
Postby hoopsbhoy » Wed, 24 Apr 2013 8:46 +0000
Hmm. Cheers.
hoopsbhoy
Postby hoopsbhoy » Wed, 24 Apr 2013 9:07 +0000
goodluck with that
Cheers, very helpful. Remind me to ask your advice in the future.
hoopsbhoy
Postby charged_rs » Wed, 24 Apr 2013 9:24 +0000
hoopsbhoy wrote:
goodluck with that
pointless giving advice to idiots who dont want to use the proper tools... so i wished you goodluck.
Postby hoopsbhoy » Wed, 24 Apr 2013 10:00 +0000
If you have nothing constructive to post don't bother posting. Thankfully others bother to be reasonable
Next time you want to refer to someone as an idiot, hold it in until you're speaking to them in person.
hoopsbhoy
Postby charged_rs » Wed, 24 Apr 2013 10:44 +0000
You are an idiot. - internet or not , if you were in front of me i would probably call you something more suitable but idiot will suffice for a public forum
asking how to swap suspension / topmounts and stating that you wont use the proper tools is hardly a question from a sensible man ergo ....idiot
Postby DIL2307 » Wed, 24 Apr 2013 11:16 +0000
goodluck with that
Please take a video for the comedy factor :x :evil: :eye: :cyclops: :oops:
DIL2307
Postby hoopsbhoy » Wed, 24 Apr 2013 11:26 +0000
Well aren't you the man. Maybe you should pull your head out of wherever you have it stuck.
I have changed countless shocks and never had to use a spring clamps while on a car. Not sure why an mx5 would be so different but we will see tomorrow.
As I said I will not be using spring clamps on or off the car. I do not trust them and with good reason.
hoopsbhoy
Postby sidewaysreilly » Wed, 24 Apr 2013 11:28 +0000
This is one for you've been framed.........
