stuck mk1 door lock
stuck mk1 door lock
Postby fez » Thu, 09 Jan 2014 12:04 +0000
So recent I've been having to get in and out of the car by taking the roof down and climbing in.
Door lock is stuck in the locked position. The key turns most of the way, but the lock seems to stop in the last few degrees of turning. Can't unlock the door from the inside, the lock doesn't slide far enough.
It has happened before and it fixed itself while I was driving.
Has anyone any ideas about how I can fix it or will it mean that I'll need to change the locks? (ignition lock is different key anyway so its not that big a deal)
fez
Re: stuck mk1 door lock
Postby scallan » Thu, 09 Jan 2014 12:44 +0000
Did u try oiling it??
scallan
Postby Steve » Thu, 09 Jan 2014 1:40 +0000
I've had something similar in the past, check out this thread :
viewtopic.php?f=12&t=3458&p=29912&hilit=lock+spring#p29912
Postby MX5Spares » Thu, 09 Jan 2014 8:12 +0000
There is a small spring in the lock that snaps off sometimes and get jammed but you need to get door trim panel off the inside to see it .Awkward.
Postby Steve » Thu, 09 Jan 2014 10:57 +0000
Yep, that's exactly it. I think I remember using a spring from a biro to get me by until I sourced a proper part.
This is where the spring is :
Postby fez » Thu, 09 Jan 2014 2:18 +0000
cheers steve, Is that photo above right at the close of the door? I think my car is falling apart enough to take the door panel off with the door closed.
fez
Postby Steve » Thu, 09 Jan 2014 6:04 +0000
the camera is in the door pointing towards the rear, halfway up the door.
Postby 93 Mk1 » Thu, 09 Jan 2014 11:22 +0000
I just done this a few weeks ago. What a difference ! The spring from MX5 Parts UK is supposed to be an ungraded part
so should be more durable than the original. Mind you, the originals are around 20 years old now....
93 Mk1
Postby fez » Sun, 19 Jan 2014 7:39 +0000
So took the door card off and everything was in its right place. Drowned it in wd40 wiggled it and the door opened!
No more dukes of hazard entries for the moment!
fez
Postby fez » Fri, 14 Feb 2014 4:41 +0000
It happened again, while the car is up with autocheck...
fez
Postby 93 Mk1 » Sat, 15 Feb 2014 2:26 +0000
Did you check that spring on the door handle ?
93 Mk1
Postby fez » Sat, 15 Feb 2014 8:40 +0000
Yep. Still there.
Fixed itself again. Might be due to lack of use!
fez
Users browsing this forum: No registered users and 34 guests
