trying to do rear led
Postby andrius7 » Thu, 12 May 2016 8:14 +0000
any one tryed to do rear leds? if you did it, please, share your pics
andrius7
Re: trying to do rear led
Postby MX5Spares » Thu, 12 May 2016 9:42 +0000
Yeah ,I would like those for mine also.Did yu check MX5Nutz forum as last year I seen lad doing it . I will search for details later
Postby notch000 » Thu, 12 May 2016 11:10 +0000
http://m.ebay.ie/itm/2X-60mm-HID-White- ... nav=SEARCH
I read that tread too, think the lad split the lens after bakibg in the oven , wired in a set of tgese and set with glue & double sided tape
Not sure of size the ones linked are only an example
notch000
Postby MX5Spares » Fri, 13 May 2016 7:06 +0000
Is that circular section not reflector?
Postby andrius7 » Fri, 13 May 2016 7:48 +0000
autocheck wrote:Is that circular section not reflector?
yes, it's reflector, i'am not happy at day time, and led's from ebay for 3eur sucks :)
andrius7
Postby andrius7 » Fri, 13 May 2016 7:51 +0000
yes, i know that tread on mx5nutz, i just used hot air gun, not oven
andrius7
Postby andrius7 » Sat, 14 May 2016 6:51 +0000
ok, so second led not working at all :(
andrius7
Postby MX5Spares » Sun, 15 May 2016 6:41 +0000
Led,s can only be fitted one way around.Swop over the bulbs(reverse them ) They are voltage flow one way only not like normal bulbs which will flow either way
Postby andrius7 » Sun, 15 May 2016 10:56 +0000
no no, it's just smth with led's, one ring has 12 parts with 3 led's, one ring has 4 sectors not working :) second ring has bad wires :) where is possibility that post man broke it whet he stuck envelope to post box :)
i used this set
http://www.ebay.co.uk/itm/400892447616? ... EBIDX%3AIT
andrius7
