Mk 1 Battery
Mk 1 Battery
Postby graham » Sun, 05 Oct 2008 6:44 +0000
Is mx5parts the best place to get a battery? Is there anywhere in Dublin that sells suitable batteries?
graham
graham
Postby ger » Sun, 05 Oct 2008 8:01 +0000
My local motor factors A&D had no problem i think it was round 50 euro.
The shipping on a battery would be crazy.
Postby Stig » Sun, 05 Oct 2008 8:18 +0000
no need to go to mx5 parts for this item.
Mines a Mk1 and I just checked my car for you as the previous owner put in a new battery prior to sale-
There's a Halfords Battery in it - its a HCB063. Just quote that ref no in Halfords and they'll sort you.
And as Ger say - any motor factor would have a battery for you too.
Just make sure it fits well and is bracked down ...hope this helps.
Rgds,
Ollie.
Battery
Postby robmx5 » Sun, 05 Oct 2008 9:21 +0000
Correct me if i'm wrong guys but the 5 is fitted with a special gel battery to avoid leaks when you throw it around corners. Normal batteries of they leak corrode the battery shelf - I think
Robin
Postby leamyj » Sun, 05 Oct 2008 9:24 +0000
Apparently the gel battery is also lighter and more expensive so unless you are really serious about authenticity then most motor factors would have one of the normal wet batteries to fit. :lol:
Postby Stig » Sun, 05 Oct 2008 9:48 +0000
Well, ya all know i like the odd donut.......and mine has'nt leaked yet! :shock: :D
http://videos.streetfire.net/video/Miat ... _46741.htm
:shock: :P :P
Postby Steve » Mon, 06 Oct 2008 12:04 +0000
leamyj wrote:Apparently the gel battery is also lighter and more expensive so unless you are really serious about authenticity then most motor factors would have one of the normal wet batteries to fit. :lol:
Which will rust the bejeasaz out of your boot. Have seen it many times. Get the gel one from MX5parts, postage isn't too bad on it AFAIR..
Postby mx5ash » Mon, 06 Oct 2008 8:40 +0000
I got one from a Motor factors as i needed it in a hurry., Standard wet battery and to big for the std mx5 holder.
Hade to make up a custom mount for it and it seems to be giving me issues with condensation (not vented to outside??)
Anyways moral of the story
Unless your in a serious hurry get a proper gel type one.
Mk 1 Battery
Postby graham » Mon, 06 Oct 2008 9:58 +0000
Thanks, I'll just order one from mx5parts.
g
graham
Postby graham » Mon, 06 Oct 2008 4:20 +0000
£22 for postage, but better than a rusty boot!
g
graham
Postby leamyj » Mon, 06 Oct 2008 6:35 +0000
You probably could have flown ryanair there and back for less (before taxes etc.,) :lol: :lol:
Postby mrges » Mon, 06 Oct 2008 9:45 +0000
WTF....two "Graham's" on the site!!
I would have to go along with Ash, the battery in my MK1 kept running flat every other day or so, and I went and got one in a hurry.....which didn't fit snuggly despite really clamping it in, and kept working itself loose (am guessing also that it wasn't "gel" as I didn't know at the time there was such an option!).
Good luck getting the battery sorted out.
Postby Fergus » Wed, 08 Oct 2008 10:47 +0000
I have a MAJOR 4x4 battery in mine :D
It will last longer than the car itself :lol:
Mk 1 Battery
Postby graham » Thu, 09 Oct 2008 11:16 +0000
I got that new battery yesterday, it only took 2 days for it to arrive, fits perfect! 10 minute job to remove the old one and replace it!
So does anyone want an old battery that occasionally needs a jump start?
graham
graham
Postby leamyj » Thu, 09 Oct 2008 1:41 +0000
You may put that in for recycling at an appropriate facility :wink:
