How much coolant do I need for a Mk1? I drained the rad when I was removing the broken bolt from the housing.
graham
CoolantHow much coolant do I need for a Mk1? I drained the rad when I was removing the broken bolt from the housing.
graham
Re: Coolant
6ltrs required for an empty system 50/50 mix with silicate free coolant (pink) / distilled water , so 3 ltrs of each
Re: CoolantPink? What's wrong with the blue stuff? When I drained the rad it wasnt pink coolant.
Graham
Re: Coolant
the blue stuff isnt silicate free and will destroy your water pump seals
