Coolant
Coolant
Postby graham » Mon, 28 May 2012 1:05 +0000
How much coolant do I need for a Mk1? I drained the rad when I was removing the broken bolt from the housing.
graham
graham
Re: Coolant
Postby charged_rs » Mon, 28 May 2012 1:30 +0000
graham wrote:How much coolant do I need for a Mk1? I drained the rad when I was removing the broken bolt from the housing.
graham
6ltrs required for an empty system
50/50 mix with silicate free coolant (pink) / distilled water , so 3 ltrs of each
Re: Coolant
Postby graham » Mon, 28 May 2012 2:14 +0000
Pink? What's wrong with the blue stuff? When I drained the rad it wasnt pink coolant.
Graham
graham
Re: Coolant
Postby charged_rs » Mon, 28 May 2012 6:51 +0000
graham wrote:Pink? What's wrong with the blue stuff? When I drained the rad it wasnt pink coolant.
Graham
the blue stuff isnt silicate free and will destroy your water pump seals
