Mazda Eunos Roadster '97 for sale
Re: Mazda Eunos Roadster '97 for sale
Postby Fla » Sat, 12 Apr 2014 4:39 +0000
very very tempting.... This is a great example, I really need to replace my retired Mk1..
Fla
---I'm back----
Fla
Postby tiggerl82 » Sun, 13 Apr 2014 4:45 +0000
The first one has the crack on it.
Mazda Eunos Roadster B2 Limited
tiggerl82
Postby turismo2142 » Sun, 13 Apr 2014 8:25 +0000
Not too bad. I'd need a full set though. I'll be seeing him tomorrow and I'll ask if he's still interested.
'92 1.6 Eunos BRG
turismo2142
Postby tiggerl82 » Sat, 19 Apr 2014 10:38 +0000
Bump
tiggerl82
Postby tiggerl82 » Sat, 26 Apr 2014 2:23 +0000
Sale suspended, due to fuckers who cut the roof this time...
tiggerl82
Postby turismo2142 » Sat, 26 Apr 2014 6:53 +0000
Ah buddy, that's awful. Dirty little f**kers. Did they take anything?
'92 1.6 Eunos BRG
turismo2142
Postby tiggerl82 » Sat, 26 Apr 2014 7:44 +0000
No, they just cut the plastic window at the back...
tiggerl82
Postby tiggerl82 » Fri, 21 Nov 2014 4:32 +0000
I still have the car. No proper offers, so I store it.
Are the axle stands fine there? I have no experience...
Thanx
tiggerl82
Postby Merlot man » Fri, 21 Nov 2014 10:14 +0000
Not sure about the support position, under the outside jacking points or under the rear diff flat spot or middle of front subframe better idea .
Couple of people looking for 5s in the wanted and I'm new sections might be worth a pm
Best of luck with it
Brian
]96 na Merlot edition. sold
99 nb 10th anniversary
93 na s ltd
Merlot man
Postby Merlot man » Fri, 21 Nov 2014 10:20 +0000
93 na s ltd
Merlot man
Postby Yolo » Sun, 23 Nov 2014 11:46 +0000
I have jacked or supported mine here if I can't put them by the jack points. I was told this was fine here because it is double skinned area and the strongest point of the rails but not anywhere else!
1992 Mk1 Eunos silver
Mk2 suspension
IL Motorsport bushes
Mk2.5 leather seats
1.8 brake upgrade
learning slowly
http://www.mazdamenders.net
Yolo
Postby retrothis » Tue, 25 Nov 2014 6:06 +0000
Tis fine, that's where I always put the stands. How you supposed to use the jacking point to jack the car up and then place the stand under exact same point? Boggles my mind :shock:
Is this your only car?
Reason I ask is cause I've three kids, number four on the way. Just turned 30 and keeping my 5. The wife drives an ould 7 seater bus, hence we've no need for a second big car. Drive my oldest to school in it every morning. So if you've one kid and two cars, the Miata can stay (unless the tax/insurance is prohibitive).
retrothis
Postby Merlot man » Tue, 25 Nov 2014 6:59 +0000
What I meant to say was to jack the car up on the rear using the flat portion of the diff and then support the car on the jacking points .
On the front use the middle of the subframe rail NOT THE ENGINE SUMP ! And then again support on the jacking points .
Hope this clears it up .
Brian
93 na s ltd
Merlot man
Postby BAwagon » Mon, 29 Dec 2014 12:54 +0000
tiggerl82 wrote:I have someone else looking for these alloys as well. Unfortunatelly one of them is cracked from the extra 4... I was planning to send to Hungary, to fix it, cause here I tried a couple of places around Dublin, nobody wanted to do it. The crack is starting from the valve hole, that is the problem...
Only found this thread.
Why did You want to send the wheel to Hungary?
BAwagon
Postby gpk157 » Sat, 03 Jan 2015 11:50 +0000
Is the car for sale at the moment? Id like to have a look at it.
gpk157
