Re: Mazda Eunos Roadster '97 for salevery very tempting.... This is a great example, I really need to replace my retired Mk1..
Fla
---I'm back----
![]() Re: Mazda Eunos Roadster '97 for saleMazda Eunos Roadster B2 Limited
![]() Re: Mazda Eunos Roadster '97 for saleNot too bad. I'd need a full set though. I'll be seeing him tomorrow and I'll ask if he's still interested.
'92 1.6 Eunos BRG
Re: Mazda Eunos Roadster '97 for saleBump
Sent from my iPhone using Tapatalk Mazda Eunos Roadster B2 Limited
![]() Re: Mazda Eunos Roadster '97 for saleSale suspended, due to fuckers who cut the roof this time...
![]() Re: Mazda Eunos Roadster '97 for saleAh buddy, that's awful. Dirty little f**kers. Did they take anything?
'92 1.6 Eunos BRG
Re: Mazda Eunos Roadster '97 for saleNo, they just cut the plastic window at the back...
![]() Mazda Eunos Roadster '97 for sale![]() I still have the car. No proper offers, so I store it. Are the axle stands fine there? I have no experience... Thanx Sent from my iPhone using Tapatalk Mazda Eunos Roadster B2 Limited
![]() Re: Mazda Eunos Roadster '97 for saleNot sure about the support position, under the outside jacking points or under the rear diff flat spot or middle of front subframe better idea .
Couple of people looking for 5s in the wanted and I'm new sections might be worth a pm Best of luck with it Brian ]96 na Merlot edition. sold
Re: Mazda Eunos Roadster '97 for sale]96 na Merlot edition. sold
Re: Mazda Eunos Roadster '97 for saleI have jacked or supported mine here if I can't put them by the jack points. I was told this was fine here because it is double skinned area and the strongest point of the rails but not anywhere else!
1992 Mk1 Eunos silver
![]() Re: Mazda Eunos Roadster '97 for saleTis fine, that's where I always put the stands. How you supposed to use the jacking point to jack the car up and then place the stand under exact same point? Boggles my mind
![]() Is this your only car? Reason I ask is cause I've three kids, number four on the way. Just turned 30 and keeping my 5. The wife drives an ould 7 seater bus, hence we've no need for a second big car. Drive my oldest to school in it every morning. So if you've one kid and two cars, the Miata can stay (unless the tax/insurance is prohibitive).
![]() Re: Mazda Eunos Roadster '97 for saleWhat I meant to say was to jack the car up on the rear using the flat portion of the diff and then support the car on the jacking points .
On the front use the middle of the subframe rail NOT THE ENGINE SUMP ! And then again support on the jacking points . Hope this clears it up . Brian ]96 na Merlot edition. sold
Only found this thread. Why did You want to send the wheel to Hungary?
Re: Mazda Eunos Roadster '97 for saleIs the car for sale at the moment? Id like to have a look at it.
