Front suspensionLooking for a good set of front shocks/springs for 1990 1.6 that is currently running on standard. just replaced rear springs due to breakage last week & while on lift saw front left broke (was ok when ordering new rear ones). To add to my woes the window cables on drivers side broke while at the garage
Re: Front suspensionDid mx5parts give any indication of how long they expect to be out of stock for??
Why not try either maguire1234 or mx5ideways?,I know they both broke 5's recently and they might have a complete regulator available...be sure to indicate left or right side..very simple to install. John
![]() Re: Front suspensionThanks for the leads. I'll probably end up waiting the 4 weeks for new ones. Then i'll stick them in while it's off road for winter. Any advice on fitting welcome. I have in the past fitted a roof but these cables look tricky. These are some cars I have mine 4 years but bought from a pal who had it since 1992 so I can say with certanity that the roof lasted (admitedly with some patching) 18 years. Exhaust still original bar the rear silencer which limped to last week. window cables and suspension to last week. I know people say thats coz its only a summer car but mine had several long lay ups by previous owner which is detrimental to running gear. This will be my first winter resting it (have banger van for dog so i'll use that). It's just pity all this stuff going together.
Re: Front suspensionAny of the workshop manuals ( I have the Rod's one) will have a detailed description of how to replace the cables. Let me know when you're doing the job and I'll photocopy and either e-mail or post/fax the relevant page(s) to you.
![]() Re: Front suspensionThanks. That will be much appreciated. I have the haynes manual but while it gives plenty info on regular mechanics and stuff that never goes wrong it gives sfa on hoods and cables.
No mystery to the cables. Connected to the front of the frame by a rivet and to the rear by a spring. Put roof almost fully down, unhook from spring, pull cable through frame/roof and replace with new rivet/small bolt+nut, then rerun cable when fitting new hood.
![]() Re: Front suspensionI replaced my front shocks and springs after finding a broken spring.The shocks I took off seem ok.You can have them if you wish.
Cheers.
Re: Front suspensionRegarding the cables. It's the electric window ones I've to replace not the roof. Thanks satfan54 for the offer. Where are you located. In kerry myself. Are you going on the kerry run in sept if so I could collect then. I would be tempted to replace springs only but my nct last oct only just passed imbalance & my springs were ok back then. Will cover you for a drink if they suit.
Re: Front suspensionYou are welcome to the shocks but the chance of me going to Kerry is slim.I am in Dublin and can give them to anyone to take to you.
Regards, Peter.
Re: Front suspensionAh Geez, don't tell me that the Dub's are so hurt, after last Sunday's drubbing
![]() Re: Front suspensionEasy on there cashel...I need those shocks! And the dubs are always welcome in the kingdom sure isn't the brogans ma from my own Listowel. Satfan I have siblings living in Islandbridge Chapelizod so i'll check with them if it's ok to drop them there. Will put details up tomorrow. Thanks.
Re: Front suspensionShur half of Dublin are from Kerry and I know they're always welcome in the Kingdom but after last Sunday they might be slow to go. 31 years is a long time and it's hurting.
![]() Re: Front suspensionGod no! Its nothing to do with muckball. Time restraints and a 5 im still working on make the journey impossible.
Cheers.
