injectors
injectors
Postby ger » Thu, 03 Dec 2009 6:36 +0000
looking for some larger injectors.
94-97 Mazda Miata 254cc - Tan Top #195500-2180
99-00 Mazda Miata 260cc - Thin Red Body #195500-3310
01-05 Mazda Miata NA & TURBO 265cc - Thin Lt. Prple #195500-406
Have to be reasonably priced. Would prefer later 260-265cc - 1999-2005 1.8 NA
Re: injectors
Postby Steve » Thu, 03 Dec 2009 8:29 +0000
shameless plug for the saab injectors I had running on mine @ 11psi ;-) See ad
Re: injectors
Postby ger » Thu, 03 Dec 2009 8:36 +0000
shameless plug for the saab injectors I had running on mine @ 11psi See ad
I still have the stock ECU, will the car idle 305cc, its at he limit.
I knew you had these for sale but thought that 265cc might be easier for the stock ECU.
Re: injectors
Postby Steve » Thu, 03 Dec 2009 9:23 +0000
ah yeah, stick with 265cc with stock ECU
Re: injectors
Postby ger » Thu, 10 Dec 2009 12:19 +0000
Sorted.
Re: injectors
Postby fabfiveferg » Thu, 10 Dec 2009 12:49 +0000
What did you get in the end Ger?
Re: injectors
Postby leamyj » Thu, 10 Dec 2009 3:07 +0000
Duh!!..he got sorted :safe:
Re: injectors
Postby fabfiveferg » Thu, 10 Dec 2009 3:28 +0000
leamyj wrote:Duh!!..he got sorted :safe:
They don't go on your head John. No wonder you've a clatter of kids
Re: injectors
Postby Stig » Thu, 10 Dec 2009 4:38 +0000
lol
Re: injectors
Postby leamyj » Thu, 10 Dec 2009 6:42 +0000
:lol: :lol: Nice one Ferg :lol: :lol:
Re: injectors
Postby ger » Thu, 10 Dec 2009 8:05 +0000
Got some tan tops from a 96 1.8, see first pic above for 50 euro on ebay, professionally cleaned too.
Needed something to do over christmas.
How are you getting on?
Did you get to the bottom of the timing issues?
Did the Air filter work out?
Re: injectors
Postby fabfiveferg » Fri, 11 Dec 2009 12:30 +0000
Air Filter is great. Haven't had a chance to sort the timing issues yet. Was in England last week. Hoping to get to it tomorrow morning. Will disconnect the Bipes altogether and see whats happening then.
Re: injectors
Postby ger » Sat, 12 Dec 2009 8:06 +0000
If you unplug the black box the car wont start, the CAS is routed through the bipes, you need to go to the ECU and locate the CAS wire (white i think but check the book) separate the wire (it should be a torpedo connection as its the only wire cut on installation) re-make the original connection and the car will start with the bipes essentially disconnected. then you can see if your timing has moved. If the timing has not corrected then i would say the mechanic got the timing wrong, do what steve said and count the teeth on the belt. it thats right then you have a faulty CAS.
