A German is trying to invade my Japanese territory
Re: A German is trying to invade my Japanese territory
Postby Steve » Wed, 09 Sep 2020 10:44 +0000
That's some work you've put in, looking great! Great save on that run
Postby Pops » Wed, 09 Sep 2020 11:13 +0000
Thanks Steve, it's taking lots of time but at the moment I've nothing else to do
Postby Pops » Sat, 12 Sep 2020 7:49 +0000
Spent hours and hours trying to fix the paint work
How poor the sprayed finish is
Fixing the massive run
After a full day compounding both sides
The next stage is to polish it but the paintwork on the bonnet turned out fairly poor with lots of dirt so I'll most likely have to spend a day sanding and compounding it then I'll be able to polish the whole car
Postby Pops » Mon, 14 Sep 2020 7:48 +0000
The amount of dirt in the paint I might as well have sprayed it on a building site
Knocked down the worst of them with 1200 grit
Then it was wet sanded with 1500 and then 3000
Again a few hours compounding to get it acceptable
Continued on with the compound and did the roof and bootlid
Postby Pops » Mon, 14 Sep 2020 9:23 +0000
If I'd got this before I started, the results might have been better Image
A good selection of tools in lidl at the moment
Postby Steve » Wed, 16 Sep 2020 9:24 +0000
results look pretty good to me! ;-)
Thanks for the tip, must have a look
Postby Pops » Thu, 17 Sep 2020 9:55 +0000
All finished now Image[img]https://uploads.tapatalk-cdn.com/20200917/]
Now have to wait until next month to tax it so I can use it
Postby Pops » Sat, 19 Sep 2020 1:59 +0000
The hopefully final job was to replace the heater controls bulbs, thanks to the world's best educator (google) I found that the bulbs are accessible by removing the knob instead of having to remove the full panel
Bulb hiding place
Used a bent pointed nose pliers to pull the bulb out, thankfully it didn't break.
Trying to fit the new bulb was a challenge, trying to keep the flap pressed back and hold the tiny bulb with the pliers was as good as impossible.
But there's always a way, s piece of heat shrink done the trick
Small screwdriver placed through it on the bulb to keep it in place while pulling back the heat shrink did the job
Postby Steve » Sat, 19 Sep 2020 9:21 +0000
Genius
Postby Pops » Fri, 25 Sep 2020 8:33 +0000
Done the hopefully final bit of work on this, replaced four blown dash bulbs, a pain to get the instrument panel out, would have been helpful if the steering column was adjustable but it isn't so to make it possible I had to remove the steering wheel, the challenge then was to find replacement bulbs, tried five different motor factors with no success, finally got them in halfords of all places
As this was the first time I've disconnected the battery I decided to do something about the battery tray
This was removed from underneath the tray with a magnet
Rust converter and a coat of paint will have to do for now
So that seems to be the end of repairs to the German but the final kick in the arse was that within the first hour of being out of the shed one of the neighbours hit it with a golf ball, it's only a tiny ding but annoying at the time
Postby Pops » Sun, 04 Oct 2020 11:11 +0000
It's never finished, bas/esp light staying on, scanner shows faulty brake light switch and steering angle sensor, switch is a common fault and as it only cost €10 so I replaced it first, success, light gone off____for 5min,so back to the steering sensor next
At least got to give it a quick spin
Postby Steve » Tue, 20 Oct 2020 11:02 +0000
oh... I had this in the past too, did you reset your steering angle after having the battery disconnected? After lots of research I discovered you could do it by turning the steering wheel from lock to lock both ways.
Postby Pops » Tue, 20 Oct 2020 11:28 +0000
Forgot about it Steve, I couldn't reset the steering angle sensor no mater what I did, a test with a better diagnostic tool found a faulty lateral acceleration sensor, got a used one for 15 pounds on eBay which solved the problem, this diagnostic tool found other problems though, there's a missfire counter and it shows misses on cyl 4, not registering enough yet to log a fault code, I've tried moving the coil to cyl 1 and the plug to cyl 2 with no difference to the missfire count, further investigation when the weather improves will be to check for a vacuum leak and swap injectors around and maybe a compression test, not too bothered about it for the time being as it drives grand
Postby Steve » Wed, 21 Oct 2020 11:54 +0000
Pops wrote:Forgot about it Steve, I couldn't reset the steering angle sensor no mater what I did, a test with a better diagnostic tool found a faulty lateral acceleration sensor, got a used one for 15 pounds on eBay which solved the problem, this diagnostic tool found other problems though, there's a missfire counter and it shows misses on cyl 4, not registering enough yet to log a fault code, I've tried moving the coil to cyl 1 and the plug to cyl 2 with no difference to the missfire count, further investigation when the weather improves will be to check for a vacuum leak and swap injectors around and maybe a compression test, not too bothered about it for the time being as it drives grand
That the sensor in the boot? I replaced that too
Are the misfires related to the nozzles you looked at before (on intake manifold side of the block) do you think? PITA to get at tho.
Postby Pops » Wed, 21 Oct 2020 1:16 +0000
Doing the vacuum test now, 3 leaks found so far, one major one was because some idiot (me) never reconnected a breather pipe on the air box, small one at what I think may be a vacuum regulator and another at the airflow meter, got to fix all these and go from there
