Halfords Trade Card
Organised a discount for mx5ireland members or starting a group buy? Heres the place to put it.
Halfords Trade Card
Postby franksm » Thu, 21 Jan 2010 10:40 +0000
Anyone have a Halfords Trade Card ? How hard are they to get ?
Found this comparison of retail vs. HTC discount prices, very interesting:
Bulbs
Brilliant Headlight (Single) RRP £9.99 TRADE £3.50
Super Brilliant Headlight (Single) RRP £14.99 TRADE £7.50
Twinpack 12V 5W sidelight bulbs RRP: £2.49 TRADE: £0.46
Halfords Bulb Hbu382 21wat. Retail 2.49 Trade 48p
halfords extreme brilliance bulb 90% brighter retail £18.99 trade £15.99
Tools
Deep 15mm 1/2 Drive Socket - RRP 5.79 - trade £4.xx
Set of 12 1/2 Drive Sockets - RRP 17.99 - trade £14.xx
Laser Brake Spanners RRP: £3.99 TRADE: £3.19
Torque Wrench RRP: £49 TRADE:£39
120piece socket set RRP:£149 (but normally on offer at £99) TRADE:£89
150piece socket set RRP:£199 TRADE:£149
Laser Scissor type Ball Joint separator RRP:16.49 TRADE: 13.19
Halfords short 1/2" drive extension bar/swivel end combination type thing RRP: £5.49 TRADE: £4.39
magnetic flexible pick up tool- RRP £6.99, TRADE £5.59.
UPDATE: Halfords professional 18mm combination spanner RRP:6.49, TRADE: 5.19 (equivalent to 20% discount - probably same on all combination spanners). For sale in Durham for RRP £6.89 - TRADE £5.51
microdriver ratchet spanner professional little tool set thingy £10 trade £8
Halfords 2 tonne ratchet axle stands RRP £14.99 - Trade £11.99
Halfords Mechanics mat (Car creeper without wheels) RRP £14.99 - Trade £11.99
22 piece Halfords professional spanner set RRP £60. Trade £47
30 piece Halfords professional screwdriver kit RRP £30. Trade £22
oil filter wrench RRP £4.99. Trade £3.21
240V inspection lamp RRP £9.99 - Trade £7.99
Halfords Professional 24mm combination spanner RRP £9.49 - TRADE £7.59
Halfords Professional 1/2" drive 30mm deep socket RRP £7.29 - TRADE £5.83
Phaze 25 piece Flex Screw Driver Set - RRP £4.99 - Trade £4.99 - Saving £0.00
Halfords pro 16" breaker bar RRP: £15.99, Trade: £12.79
Deep 11mm 1/2 inch socket - RRP - £4.79 - Trade - £3.89
Bell Oil Drainer Can DC0601. RRP £4.79 - Trade £ 3.83
PRS Flex Spout Oil Funnel. RRP £3.99 - £ 3.19
Service parts
polo mk2 timing belt RRP £8.99 - TRADE £2.76 (CHEAPER THAN GSF!! )
Polo mk2 water pump RRP £32.99 -TRADE £21.11
halfords brand rear wheel bearing suit mk1 golf/polo RRP £11.99 Trade £8.37
Comma CV & Lith-Moly Grease 500G £5.49 Trade £4.39
BK 5000 universal cv boot kit, about £9-10 trade £3.64
Ignition components
Halfords Rotor arm HRA500 RRP £4.99 - Trade: £2.16
Glowplugs for 1.9 Diesel 206 RRP: £29.99 TRADE: £18.08
205 Distributor cap - RRP 8.99 Trade £6.19
Halfords set of 5 H.T leads RRP: £12.99 TRADE: £6.38
NGK 804 Sparkplugs - £9.99 RRP to trade £3.49
4 NGK spark plugs Grooved RRP £11.99 TRADE £4.32
Oil filters
Halfords Oil Filter for Ford Puma 1.7 RRP £5.29 - TRADE £1.90
Halfords OIL Filter for Citroen Xantia 2.0 8v RRP £6.49 - TRADE £2.01
Halfords Oil Filter for Toyota Yaris 1.0 RRP £5.99 - TRADE £2.44
Halfords Oil filter HOF204 - Trade £2.01
Halfords Oil Filter HOF265, various Ford, Jaguar RRP £5.29 - TRADE £1.90
Oil filter (either Halfords or Champion) for Toyota Starlet RRP £5.99. Trade £2.21
Halfords Oil Filter HAF293 - RRP £5.99 - Trade £3.70 - Saving £2.29
HOF237 (Nissan) RRP - £7.49, TRADE - £2.40
HOF301 (V/hall) RRP - £7.49, TRADE - £5.64
Halfords Oil Filter (HOF200, Saab) RRP - £3.99, TRADE - £1.74
oil filter for ford focus 1.6 04, part number HOF 265 RRP £5.79 TRADE £1.90.
Air Filters
HAF 249. Retail £9.99 Trade £2.44
HAF 410 RRP £14.99 - Trade £11.59
HAF 281 (Nissan) RRP - £10.79, TRADE - £4.82
HAF 366 (V/hall) RRP - £7.79, TRADE - £4.78
Fuel filters
HFF232 (Nissan) RRP - £11.99, TRADE - £6.66
HFF219 Fuel Filter - No idea on retail as it was from back room - Trade £5.39
fuel filter for 1.6 ford focus 04, part number HAF 283 RRP £11.79 TRADE £9.19
Halfords Fuel filter Xantia RRP £10.49 TRADE £6.30
Filters - others
Pollen Filter 006 RRP £9.99 - Trade £5.99.
Odds n Ends
Tube of Easy Gasket - RRP £4.99 TRADE £1.90
Loctite Instant Gasket - £3.99 Trade - £2.01
Halfords Split Pin selection approx 550 6 different sizes RRP: £6.99 TRADE: £4.99
Halfords Rocker switch RRP: £1.79 - Trade: £1.43
engine stop leak wynns £5.49 trade £4.49
halfords copper grease 500g £6.99 trade £3.88
pittards leather chamois rrp £15.99...no trade discount.
Reddex Petrol 1 litre RRP £9.99 - Trade £7.99
Superflex Windscreen silicon sealant RRP £4.49 - Trade £4.04
AirCon refrigerant top-up with pressure gauge RRP £39.99 - Trade £31.99
Loctite Stud 'n' Bearing sealant RRP £2.99 - TRADE £2.69#
Turtle Wax Ice Wax - RRP £12.99 - Trade £12.99 - Saving £0.00
Holts Tyre Weld - Large RRP £ 8.99 - Trade £8.99 - Saving £0.00
Halfords Tyre Tread / Pressure Kit - RRP £6.99 - Trade £6.99 - Saving £0.00
Wynns Engine Flush - RRP £4.99 - Trade £3.99 - Saving £1.00
WD40 250ml RRP £2.49, TRADE - £1.99
Halfords Fuel Hose HFH402 (1m length, 8mm diam) RRP £4.29, TRADE - £2.39
Halfords Trim Rivets (plastic) HFX363 - RRP £2.49 - Trade £1.99
Halfords Crimp & Terminal 'selection box' 180 pieces HBB105 - RRP £6.99 - Trade £4.99
Number plates: no discount for trade
Heatshrink tubing pack - RRP £6.99, Trade: £3.99
5 amp cable 7 metres various colours - RRP £2.99, Trade: £2.39
Copper Grease RRP £3.49 Trade £1.33
Halford's Fused Cigarette Lighter Plug RRP £2.99 TRADE £2.49
Sprays
Halfords Grease Spray RRP £3.99- Trade £3.19
3-IN-1 Professional silicon spray RRP £4.99 - TRADE £3.99
Loctite Freeze and Release spray RRP:£2.99 - TRADE £2.39
3 in 1 cleaner degreaser £ 4.49 trade £3.59
wynns carb/intake cleaner spray £4.99 trade £2.96
3-In-One Pro Copper Grease (aerosol) - RRP £4.49 - Trade £3.59
Cooling system
1ltr antifreeze RRP: £4.29 TRADE: £3.43
Holts Radweld RRP: £3.99 TRADE: £0.99
Halfords coolant hose repair bandage - RRP £2.99 - trade £2.44
halfords anti freeze 1ltr got 70p off.
Halfords Hose Clip ( the big Jubilee clip) RRP £1.59 TRADE £0.49
Thermostat + Fitting Kit for Citroen Xantia 2.0 petrol RRP £15.04 TRADE £11.28
Anti-Freez 5 liters can "2 yrs life" RRP £17.99 TRADE £14.69
Brake stuff
EUROPART ViziBleeding Kit ( with container) RRP £5.99 - TRADE £3.55
EUROPART ViziBleeding Kit ( without container) RRP £4.99 - TRADE £2.49
Halfords brake cleaner RRP: £5.49 TRADE: £4.39
Big Can of Brake and Clutch Cleaner - RRP £5.99 - (sounded expensive and it's a huge can)
Halfords Dot4 brake fluid - massive 5 litre can RRP: £15.99 - Trade: £10.21 (£2.04 per litre)
Ferrado Brake shoes for Fiesta, Ka, etc = £23.99 Trade £15.
Exhaust stuff
Halfords Exhaust Repair Bandage RRP£3.29 - TRADE £1.21!!
Holts Gun Gum Putty (for holes in backbox) - RRP £3.79 - Trade 76p!!
rubber exh hangers 34MM "O" style RRP:79 PENCE TRADE:55 PENCE
gun gum £3.79 trade 76p
fire gum £3.79 trade £2.17
Holts Flexiwrap for fixing the back box (the wide metal sheet) RRP £6.49 TRADE £4.20
Holts Flexiwrap for fixing the exhaust pipe into the back box RRP £5.49 TRADE £4.36
Holts Flexiwrap for fixing the exhaust pipe RRP £5.29 TRADE £3.30
Wipers
bosch wipers 23/21 retail £36.99 trade card £27.99
halfords wiper set 56. retail £23.99 trade card £12.13p
Windscreen Wiper Blade (Rear) - RRP £9.99 TRADE £3.47
bosch s/p wiper blade 19 retail £9.99 trade £4.45
21/19s bosch wiper set £18.99 trade £10.59
Set 20 wipers halfords (21inch spoiler and 19 inch blades same as bosch fitments) £14.49 trade £5.94
Bosch s/p Wiper Blade 15 RRP £7.49. Trade £4.22
Halfords Wiper Blade w22 17 RRP £6.79. Trade £2.70
Halfords rear wiper W13 RRP £6.39 - Trade £1.95
Batteries + Cables
hb065 battery £69.99 trade £45.14
hcb065 calcium 4 yr guarantee battery £79.99 trade £52.44
hb075 battery £74.99 trade £51.21
hcb075 calcium battery £84.99 trade £54.25
merc battery(one in boot) RRP: £99 TRADE: £71
Halfords Earth Cable 22cm RRP £3.99 - TRADE £3.19
Hyundai Coupe Battery RRP £96 Trade £71
Oil
15/40 5l part synthetic Oil - Trade £12.74
Castrol Magnatec 5W30, 4 Litres, RRP £27.99 - TRADE £22.39
Halfords Fully Synth 5w/40 Oil 5l. RRP - £34.99, TRADE - £26.24
Paints/Primers etc
upol weld thru primer RRP £10.99 TRADE £9.89
Aluminium spray paint RRP £5.79 - Trade £5.21
Touch up paint set, Vauxhaull Satin Red RRP £10.49. Trade £9.44
Primer spray paint RRP £5.79 - Trade £5.21.
Clear Laquer spray paint RRP £5.79 - Trade £5.21.
Halfords Alloy Wheel Repair Kit. RRP £29.99 - Trade £ 26.99
No discount on mixed paints.
Books and Manuals
Haynes manual 3797 ( Astra/Zafira diesel 1998-2004) RRP £18.99 Trade £15.19
Haynes Manual 3511 ( Mercedes C-Class ) RRP £19.99 TRADE £15.99
Re: Halfords Trade Card
Postby leamyj » Fri, 22 Jan 2010 10:21 +0000
I think Ollie got one of them
Postby Stig » Fri, 22 Jan 2010 11:04 +0000
Yes, I do. :wink:
Postby Steve » Fri, 22 Jan 2010 12:00 +0000
I feel a group buy coming on.. :mrgreen:
Postby Stig » Fri, 22 Jan 2010 12:14 +0000
srigley wrote:I feel a group buy coming on.. :mrgreen:
would'nt be the first time my card was used to buy for some comrade's here.. :D
Postby franksm » Fri, 22 Jan 2010 12:27 +0000
How does one get a card and how easy is it ? What's involved ?
Postby Stig » Fri, 22 Jan 2010 12:52 +0000
franksm wrote:How does one get a card and how easy is it ? What's involved ?
Frank,
I just got to know the bloke in my local Halfords by having the craic with him.
He was a great guy (he's gone now to carrikmines shop), into his cars (has an FTO) and I asked for one and he gave me one as he knewIi was in every so often getting bit's and bob's.
I then asked about getting one for all of us here in mx5ireland and he put as call into their trade manager but the guy never ever rang me back........I might chasse that up...leave that with me.
Still, I think from memory taxi drivers qualify too as well as trade people.
It's handy to have, and has saved me QUITE a few bob esp. on mobil1 oils etc.
Very handy too to have on a Sunday or Sat Afternoon when the motorfactors are closed too. I only used the card there the other day getting oil for the wifes jeep - i got 2 x 5 litres of Halford own brand 10W40 turbo diesel oil - decent quality oil supplied to Halfords by Comma oils,so its ok stuff - only €14 ea with the trade card!
Actually, is carrickmines your local halfords Frank?, my olde mate may sort you there, I can give him call etc.
Postby franksm » Fri, 22 Jan 2010 12:57 +0000
Liffey Valley would be my closest but I prefer Carrickmines as it lets me stretch my legs to/from :-)
Yeah - I have been in there quite a bit. Should have sorted this sort of thing out a while ago ! lol
Postby Stig » Fri, 22 Jan 2010 1:00 +0000
franksm wrote:Liffey Valley would be my closest but I prefer Carrickmines as it lets me stretch my legs to/from :-)
I'll look into it ......leave it with me!
Postby Stig » Fri, 22 Jan 2010 1:14 +0000
Sorted! :alien:
Frank, txt on way to you.......
O
Postby franksm » Fri, 22 Jan 2010 1:29 +0000
Class, dude. Multiple pints headed your way - or else a box of real Jaffas at the next tech day.
BTW we had some FTOs on a Sunday meet a year or two ago. Wonder if he was one of them. Lovely cars - I prefer the v6 version over the RX8, even though they are 10 years older !
Postby Stig » Fri, 22 Jan 2010 7:58 +0000
franksm wrote:Class, dude. Multiple pints headed your way - or else a box of real Jaffas
I'll take the first option! :mrgreen:
ok Gang, easy on the pm's re; trade cards.
I'm seeking to directly get in touch with the Trade manager for Halfords in Ireland with a view to requesting one for everyone here in the audience.
I'll see how she goes and keep you posted!
O
Postby fabfiveferg » Sun, 24 Jan 2010 8:21 +0000
PM sent
Postby anniniwa » Sun, 24 Jan 2010 10:54 +0000
I checked it out at our local Halfords in Limerick a few months back and was told they were fairly easy to obtain until they brought in new forms etc which need to be faxed to head office before any new cards would be issued.
Well done Ollie if you sort something out.
Postby barney » Tue, 26 Jan 2010 11:26 +0000
asked in my local store before xmas and was told they would check. went in today and they said only trade and when i mentioned taxis they said that it's now only one card per taxi company. head office policy.
Return to Members discounts and group buys
