Alignment/Geometry
Alignment/Geometry
Postby Richie L » Sun, 14 Feb 2010 3:16 +0000
Can anyone suggest a good place to get the geometry done and anyone got any knowledge of settings that work in Ireland for the mk 2.5.Looking for good turn in with back end stability and expecting higher tyre wear.Thanks
Richie L
Re: Alignment/Geometry
Postby Ivan » Sun, 14 Feb 2010 7:29 +0000
Steve will be along to tell you about the lanny settings.
Blakes cross for alignment
Postby Steve » Mon, 15 Feb 2010 1:48 +0000
heh, Lanny's have a fair bit of toe in (and are soooo 1999 ;-) )
The IceHawk specs have more toe out for quicker turn in (but your straight line will be a bit twitchy).
Front
Caster: Maximum
Camber: -1.5°
Toe out 1/16" per side
Rear
Camber: -2°
Toe in 1/16" per side
I went with oem settings after doing polys, alignment bolts, inner + outer tie rods. That kept it chuckable. Lanny's just weren't for a daily driver (well.. not for my daily driver). I've read good things about the FM settings too tho' :
Front
Caster: 5.0 degrees
Camber: 1.0 degrees negative
Toe: 1/16" total (1/32" per side)
Rear
Camber: 1.5 degrees negative
Toe IN: 1/16" total (1/32" per side)
Were you up there lately? I used to rate Blake's cross but yer man didn't want to know about anything other than "wutz eenn dee mahceen" last time I was there. No sign of the good old school guy (Barney/Billy?) that used to be there :-( Granted, that was about 4 years ago.
Postby Ivan » Mon, 15 Feb 2010 1:58 +0000
I was up there twice last year. Did it grand. In 2008 they did the Porsche and it came out worse than it went in. Got it sorted though.
Postby sidewaysreilly » Mon, 15 Feb 2010 10:42 +0000
are you sure you dont mean toe in on the front leaves it twitchey?????
Postby Steve » Mon, 15 Feb 2010 1:27 +0000
toe in, better higher speed stability
toe out, better lower speed cornering
Postby aquarian5 » Mon, 15 Feb 2010 8:54 +0000
Ivan wrote:I was up there twice last year. Did it grand. In 2008 they did the Porsche and it came out worse than it went in. Got it sorted though.
More info please Ivan...how did they sort it, did they just fine tune their alignments settings a bit more.
Got the alfa done recently again handling not as sharp as it was before..just wondering if I bring it back again are they gonna say 'thats what the machine recommends'............ :roll: :shock:
Postby adamaca » Sun, 07 Mar 2010 1:35 +0000
It drives me mental Ive never once been totally happy with an alingment, there generally just not arsed, it takes the guts of an hour to get the settings right you adjust one the other goes off etc, id love to have my own gear.
adamaca
Postby sidewaysreilly » Sun, 07 Mar 2010 1:56 +0000
piece of string can be usefull. Try doing it with coilovers............aaaaaargh!!!!
Return to General discussion
Users browsing this forum: No registered users and 9 guests
