Flywheel
Postby deccydoo » Sun, 17 Jan 2010 10:24 +0000
just a quick question there if any1 knows, is it possible to get some1 to lighten a stock flywheel on a lathe and balance it?
deccydoo
Re: Flywheel
Postby Steve » Sun, 17 Jan 2010 11:51 +0000
yup, it is. You thinking about it?
Re: Flywheel
Postby deccydoo » Thu, 21 Jan 2010 6:29 +0000
defo, the clutch is nearly on the way out so i was thinking of picking up a second hand 1.8 flywheel and getting it done for when the clutch goes
deccydoo
Re: Flywheel
Postby sidewaysreilly » Sat, 23 Jan 2010 12:41 +0000
tread carefully on who balances it for you. It should really be dynamically balanced with the crank...
Re: Flywheel
Postby deccydoo » Sat, 23 Jan 2010 5:29 +0000
thanks for the info, the whole thing is a bit above my head, any recomendations as to who might be good to do it and how much id be looking at
deccydoo
Re: Flywheel
Postby leamyj » Sat, 23 Jan 2010 5:49 +0000
Probably a stupid question, but why do you want to alter the flywheel??
Re: Flywheel
Postby Steve » Sat, 23 Jan 2010 6:53 +0000
Re: Flywheel
Postby charged_rs » Sat, 23 Jan 2010 8:49 +0000
you are probably better off getting a used oem mazda one from one of the limited editions. rs ltd and r-ltd , vr-ltd etc
The jap import limited editions(mk1) weigh in at 12lbs compared to the standard 21 lbs
makes a huge difference , especially if you have a supercharger strapped on
can be had usually for circa 100 quids , give or take a bit ;)
Re: Flywheel
Postby deccydoo » Sat, 23 Jan 2010 10:19 +0000
check out steves link john, it explains it a hell of a lot better than i would!
$160 certainly cheaper than a new 1. ill email them on shipping costs.
Do you have any idea if the lightened flywheel was on the mk2 rs?
deccydoo
Re: Flywheel
Postby leamyj » Sat, 23 Jan 2010 10:52 +0000
Now I see, very interesting and informative..TA!!
Re: Flywheel
Postby Steve » Sun, 24 Jan 2010 2:14 +0000
deccydoo wrote:check out steves link john, it explains it a hell of a lot better than i would!
Ask them if they'll ship via registered USPS.. they can be a fair bit less and almost as fast as the couriers. Think you can get them to do pick ups too online.
Re: Flywheel
Postby charged_rs » Sun, 24 Jan 2010 2:31 +0000
the stock mk2 rs flywheel is 21lbs but the one i had in my written off one is 12lbs
i managed to buy it back off the insurance company tho and will be pulling the engine for a guy who is collecting it next weekend.
3 days before it was written off i had only flippin fitted a new clutch :(
Re: Flywheel
Postby ger » Sun, 31 Jan 2010 9:20 +0000
Is this your daily driver?
If so read up on the drawbacks of light weight flywheels.
Ones i know of are increased gear lash noise in the box (not a nice sound when engine braking)
Also lumpier running in some aspects of driving due to less inertia.
Re: Flywheel
Postby charged_rs » Sun, 31 Jan 2010 10:58 +0000
ger wrote:Is this your daily driver?
these would apply to severely lightened flywheels only - sub 8lbs esp aluminium ones
the factory lightened flywheels have all the benefits with no drawbacks ;)
Return to Engine Mods
