Removing the cat,emissions??
Postby eyore » Fri, 18 Nov 2011 5:15 +0000
If I remove my catalytic converter and replace it with a non cat silenced box will the car be ok for NCT emissions? Anyone done this.I seem to remember I did it with a Fiat Coupe one time and it was ok, but cant remember for sure as I may have replaced the cat for the test. :?
eyore
Re: Removing the cat,emissions??
Postby paulNA » Fri, 18 Nov 2011 5:31 +0000
what year is your mx?
if its 93 car or older you will get away with taking out the cat, as it wont be properly emission tested ,
ps. i have spare decat for mx5 here if your looking for one handy
paulNA
Postby eyore » Fri, 18 Nov 2011 6:22 +0000
paulNA wrote:what year is your mx?
The car is a 93 so I should be ok, thanks for that :D :D Wish I'd known you had one before I ordered from MX5 parts :shock: My own fault for not asking first. :roll:
eyore
Postby MaXimu5 » Wed, 23 Nov 2011 12:31 +0000
Hi Paul,
What is the advantage of removing the cathalyser? My car is an 92 eunos 1.6 auto. Would your de-cat be suitable for this car?
MaXimu5
MaXimu5
Postby eyore » Wed, 23 Nov 2011 12:22 +0000
MaXimu5 wrote:Hi Paul,
MaXimu5
The two things noticed immediately are a more rorty noise,its not loud because its a silenced decat pipe but definitely nicer.
The other thing is its far more willing to rev freely especially at the lower revs, which can't be bad.
eyore
Postby sifpilsen » Wed, 23 Nov 2011 6:28 +0000
and something like 2 or 3 HP more, depending on what kind of cat was on, and how much buildup was inside it. But, as with a conefilter, mostly for the sound, not much to pick up on a dynorun.
x-'91 1.6
x-'94 1.8
sifpilsen
Return to Engine Mods
