Bipes ACU
Postby fez » Thu, 16 May 2013 4:11 +0000
Anyone any experience with these? Looking in the future to try and get more power out of the mx5 without forced induction. What can a megasquirt do that these can't? Can I get rid of the AFM with it? I've a 92 1.6 S Special.
fez
Re: Bipes ACU
Postby charged_rs » Thu, 16 May 2013 11:50 +0000
bipes is a unit to retard your timing under boost , 6 wires iirc
they are pretty basic and very crude and a megasquirt will run rings around it all day long.
Re: Bipes ACU
Postby fez » Fri, 17 May 2013 10:53 +0000
but for the money and on a naturally aspirated engine is it worth getting? or is it worth getting a megasquirt even? I saw these dyno results on an na enginehttp://www.invisiblesun.org/Miata ... _MaxHP.jpg
I could get one reasonably cheap brought back from the us by a mate if they were any use.
fez
Re: Bipes ACU
Postby charged_rs » Sat, 18 May 2013 11:03 +0000
fez wrote:but for the money and on a naturally aspirated engine is it worth getting? or is it worth getting a megasquirt even? I saw these dyno results on an na enginehttp://www.invisiblesun.org/Miata ... _MaxHP.jpg
a bipes retards timing when it sees boost , so as you are NA then you will never see boost and therefore do not need any retard
if i were you i would save your money , aftermarket ecus are no good unless you are boosted or have lots of engine work done...but if you have the cash to splash , buy something good , not a bottom of the range megasquirt - try an AEM ems or a hydra.
Aftermarket ecu's / piggybacks need tuned properly or else you will be on the hunt for a new engine and yes m, they might look cheap now , but add in dyno ttime and buying additional sensors and it gets very expensive very quickly
Re: Bipes ACU
Postby rhysmate » Sat, 18 May 2013 11:23 +0000
Why waste your time and money on an ecu thats going to cost more than the car? AEM and Hydra are for racing cars that put out huge power and a apparently extremely hard to work with..
I also wouldnt consider megasquirt ''bottom of the range'' and they aren't as hard to tune as people think. I tuned my own engine after a few weeks of research and you can ask some of the lads that have seen it, its perfectly 'adequate'
But ya, a bipes is useless for NA and i wouldn't be inclined to use it on a boosted engine either.
Re: Bipes ACU
Postby sidewaysreilly » Sat, 18 May 2013 11:44 +0000
I have a Bipes fitted to our yoke. (mk2 RS engine in a mk 1) . Its easy to fit but does not give you more power. What it will allow you to do is advance the low end timing to give better low to mid-range pick up and then pull the timing back to static (10,12,14, whatever you want) when it senses more airflow/load at high rpm. The 14 degree timing mod does the same(gives better low to midrange pick-up) but sacrifices top end power very noticably.So, the bipes does work to some extent if you drive the complete nuts off the Car. Gives you the best of both worlds .
I'll be selling it soon but only to go Turbo with an aftermarket ecu.
Re: Bipes ACU
Postby charged_rs » Sat, 18 May 2013 2:59 +0000
its whatever he wants really and what he can afford
if you buy a megasquirt apparently you get a free shocker sticker and a hoodie and some sweatpants to make you even cooler.....or maybe when your car isnt running properly you can run yourself home lol
Re: Bipes ACU
Postby rhysmate » Sat, 18 May 2013 3:40 +0000
charged_rs wrote:its whatever he wants really and what he can afford
Original.. we'll see when i get it dyno'd.. but judging by your dyno graph i dont have alot of competition anyway.. 8)
Hey look what a google search finds! Wierd...
Re: Bipes ACU
Postby sidewaysreilly » Sat, 18 May 2013 4:40 +0000
a dyno shoot-out. Now there's an idea. Who has the biggest turbo, most boost etc etc..............
Re: Bipes ACU
Postby rhysmate » Sat, 18 May 2013 4:47 +0000
Ill be doing it in august after my holiday.. ill be going to Dublin Nice and central(ish) with Joe Power. Itd be interesting to have them all together so if you want i can organise it.
Re: Bipes ACU
Postby charged_rs » Sat, 18 May 2013 6:43 +0000
rhysmate wrote:
Original..
you must be used to people thinking that you are twat then
Re: Bipes ACU
Postby rhysmate » Sat, 18 May 2013 6:57 +0000
Good comeback.
Not sure if youre aware but original means fresh or inventive. So your comment makes no sense.
Re: Bipes ACU
Postby sidewaysreilly » Sat, 18 May 2013 8:14 +0000
seconds out, round 3eeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Re: Bipes ACU
Postby Steve » Sat, 18 May 2013 10:20 +0000
Guys take the BS to PM/email if you want to continue.
Would be interested to hear more about ECU alternatives in this thread.
Sent from my GT-I9300 using Tapatalk 2
Re: Bipes ACU
Postby charged_rs » Sat, 18 May 2013 11:01 +0000
its ok steve , i wont be posting again...the forum is being overrun with this new breed of stanced chav twats who are limited to a budget of dole monies and who know everything apparently...bye
Return to Engine Mods
