Problem while changing into 2nd gear
Postby Peter W. » Sat, 17 Dec 2011 7:04 +0000
I do have problem while changing up into 2nd gear.i can hear bit of a clanky noise
i've spotted that my upper shift boot is cracked and that small nylon cup on the base of gearleaver is not in perfect codition as well(small crack on one side)
can that be a reason??
i have to mention that gear oil was changed recently...
many thanks for any advise
Peter W.
Peter W.
Re: Problem while changing into 2nd gear
Postby sidewaysreilly » Sat, 17 Dec 2011 7:09 +0000
Is it a 5 or 6 speed?? Shift booths do cause it on 6 speeds but if the cup is damaged then it will cause trouble.
Postby Peter W. » Sat, 17 Dec 2011 7:17 +0000
its 6 speed
so next job is to replace that nylon cup
lucky its cheap but i'll do shift boot as well so i wont have to smell the gear oil inside as i drive
thanks a lot
Peter W.
Postby sidewaysreilly » Sat, 17 Dec 2011 7:21 +0000
In the process of putting a 6 speed in mine. Booths done. Check which cup you need as the later ones are larger. Otherwise kit is the same for both mk1 & 2 from mx5parts.
Postby Peter W. » Sat, 17 Dec 2011 7:27 +0000
it seems that i have to check my vin to now which one i need.i'm already checking mx5parts.co.uk and seems that its the small one
but obviously will double check that before buyin'
thanks again
Peter W.
Postby sidewaysreilly » Sat, 17 Dec 2011 7:38 +0000
Here they are, bigger/later one is much bigger.
http://www.mx5parts.co.uk/product_info. ... cts_id/696
click on the image and then click next to see dimensions of both.
Postby Peter W. » Sat, 17 Dec 2011 7:43 +0000
thanks
i've found it
Peter W.
