Re: Mk1 Charge & Heat lightany good garage will braze one up for you. Get some piping of the same outside diameter , cut it to the 2 required lengths, drill a hole in the side of one and braze the shorter piece on. You should be able to pull the rotten origional out easily enough.
![]() Re: Mk1 Charge & Heat lightWe have good used housings in stock ?.....
