Mk1 Charge & Heat light
Re: Mk1 Charge & Heat light
Postby sidewaysreilly » Sat, 19 Jan 2013 5:35 +0000
any good garage will braze one up for you. Get some piping of the same outside diameter , cut it to the 2 required lengths, drill a hole in the side of one and braze the shorter piece on. You should be able to pull the rotten origional out easily enough.
Postby MX5Spares » Sat, 19 Jan 2013 5:40 +0000
We have good used housings in stock ?.....
