NCT CO Emissions Fail
Re: NCT CO Emissions Fail
Postby Randy » Mon, 18 May 2015 1:02 +0000
Mine failed on Saturday as well.. Pretty much the same results as before replacing the cat.
Going to have a look at the AFR, and maybe weld on a second cat (Out of other ideas at this stage).
Randy
Postby Johnny » Thu, 21 May 2015 4:40 +0000
Sorry to here that, let us know if you get it sorted.
Johnny
Postby MX5Spares » Thu, 21 May 2015 7:14 +0000
The 914 I am rebuilding passed with good used cat fitted .Reading were 1.1 and limit is 3.3 so well under.and cert til July 2016.!!
Postby Randy » Mon, 01 Jun 2015 1:50 +0000
Tried again, but still no success.
They were down a good bit after adjusting the AFR, but the lambda was way out..
Going to try one more time, and go mental on the AFR to see if it can pass.
Randy
Postby Johnny » Mon, 01 Jun 2015 6:10 +0000
The lambda reading relates to oxygen I think, so maybe a vacuum/air leak in the intake after the AFM or in the exhaust or oxygen/lambda sensor needs replacing.
Johnny
