Hi guys,
My '93 Mk1 is due to have it's cam belt changed. Can anyone tell me if
if's straight forward ? Is the water pump run off the belt also and what
else should I replace while I'm at it ?
Also over the last few days I have noticed a squeak when I reverse
when the clutch is left out. If I leave the car roll back in neutral or in
reverse with the clutch pressed in then it's fine. Any ideas ??
Maybe the mice have moved in........!
