Really basic question here:
I want to replace my gearbox oil - the manual shows topping up from the level hole in the side of the gearbox - easy, I can understand that one, however, later on, it shows topping up with the shift lever removed, from inside the car - is this the same thing, or are there 2 different areas to top up with oil in there?
As you can see, not too much of a clue about gearboxes.
