Gearbox Fluid
Gearbox Fluid
Postby K10 » Fri, 22 Feb 2008 12:10 +0000
Really basic question here:
I want to replace my gearbox oil - the manual shows topping up from the level hole in the side of the gearbox - easy, I can understand that one, however, later on, it shows topping up with the shift lever removed, from inside the car - is this the same thing, or are there 2 different areas to top up with oil in there?
As you can see, not too much of a clue about gearboxes.
K10
Postby MX5Steve » Fri, 22 Feb 2008 9:34 +0000
Yep thats correct I did mine before xmas, and I got confused aswell. It's a different pot for lubricating the shift linkage (I think!!!!).
If your doing it you might want to replace your shift boots. see the link below. Some sites advise you get a turkey baster and suck out any waste oil from it and then top it with luvly new stuff.....
http://www.camsmx5.com/Resources/techshift/techshift.html
Postby K10 » Fri, 22 Feb 2008 11:47 +0000
Any idea how much i should put in there?
Edit: Sorry, just looked at the link, question answered - just fill er up.
Thanks.
K10
