Steering
Steering
Postby rockdrummer4 » Mon, 16 Oct 2017 12:53 +0000
Hey guys,
Power steering is a bit weird, shudders when turning the wheel, also makes a hissing noise when turning..
Had the belt changed recently.
Any ideas, 93 mk1...
thanks C
rockdrummer4
Re: Steering
Postby Pops » Mon, 16 Oct 2017 2:41 +0000
Sounds like low fluid level, is the belt tension correct
Re: Steering
Postby rockdrummer4 » Mon, 16 Oct 2017 5:49 +0000
Hey pops, thanks I think the belts look fine.
Will check the fluid tomorrow once this storm blows over :)
Cheers,C
rockdrummer4
Re: Steering
Postby rockdrummer4 » Tue, 17 Oct 2017 9:19 +0000
Fluid was very low, so topped it up but still the same. Filled it up with Dexron 3 ATF
I dont think its the belt cause when the AA guy replaced the belt last week, we test drove it and it was fine, just now it is still very stiff!!
Does it take a while for the fluid to work its way through or any ideas?
Thanks C
rockdrummer4
Re: Steering
Postby Pops » Tue, 17 Oct 2017 12:18 +0000
If it empties altogether and you keep using it you may have damaged the pump. If the pump was dry and you refilled it try raising the front of the car a bit ( just to make it easier to turn the steering) and , with the engine running Turn the steering lock to lock multiple times to purge the air out of the pump and rack
Re: Steering
Postby rockdrummer4 » Tue, 17 Oct 2017 1:01 +0000
Cheers Pops
Will try that and see, but have feeling may have damaged the pump tho...
rockdrummer4
Re: Steering
Postby MX5Spares » Tue, 17 Oct 2017 4:48 +0000
Doubt the pump will be damaged but we have some anyway. Try full lock left to right few times with engine running ,as above.It should come back to normal
Re: Steering
Postby rockdrummer4 » Wed, 18 Oct 2017 1:36 +0000
Thanks guys, working the steering wheel did the trick, took a while about 20 mins !!
rockdrummer4
Re: Steering
Postby mrges » Wed, 18 Oct 2017 3:08 +0000
That's great you got sorted out - and for minimal expense.
Re: Steering
Postby MX5Spares » Wed, 18 Oct 2017 6:59 +0000
Colin, monitor it for leak as obviously fluid went somewhere and may leak again
Re: Steering
Postby rockdrummer4 » Thu, 19 Oct 2017 9:46 +0000
Cheers Rob,
Will keep a close eye..
C
rockdrummer4
