Hey guys,
Power steering is a bit weird, shudders when turning the wheel, also makes a hissing noise when turning..
Had the belt changed recently.
Any ideas, 93 mk1...
thanks C
SteeringHey guys,
Power steering is a bit weird, shudders when turning the wheel, also makes a hissing noise when turning.. Had the belt changed recently. Any ideas, 93 mk1... thanks C
Re: SteeringSounds like low fluid level, is the belt tension correct
Re: SteeringHey pops, thanks I think the belts look fine.
Will check the fluid tomorrow once this storm blows over Cheers,C
Re: SteeringFluid was very low, so topped it up but still the same. Filled it up with Dexron 3 ATF
I dont think its the belt cause when the AA guy replaced the belt last week, we test drove it and it was fine, just now it is still very stiff!! Does it take a while for the fluid to work its way through or any ideas? Thanks C
Re: SteeringIf it empties altogether and you keep using it you may have damaged the pump. If the pump was dry and you refilled it try raising the front of the car a bit ( just to make it easier to turn the steering) and , with the engine running Turn the steering lock to lock multiple times to purge the air out of the pump and rack
Re: SteeringCheers Pops
Will try that and see, but have feeling may have damaged the pump tho...
Re: SteeringDoubt the pump will be damaged but we have some anyway. Try full lock left to right few times with engine running ,as above.It should come back to normal
Re: SteeringThanks guys, working the steering wheel did the trick, took a while about 20 mins !!
Re: SteeringThat's great you got sorted out - and for minimal expense.
Re: SteeringColin, monitor it for leak as obviously fluid went somewhere and may leak again
Re: SteeringCheers Rob,
Will keep a close eye.. C
