More containers for used oil etc
much easier getting through this lot than the 60 bottles of beer
 Re: Winter hibernation repair projectsMore containers for used oil etc  much easier getting through this lot than the 60 bottles of beer You do not have the required permissions to view the files attached to this post.
 Re: Winter hibernation repair projectsStill haven't done the alignment, but at least I have it ready to be done when I build up the courage to spend more than a few minutes in the cold shed, getting a bit lazy really, anyway the nct has been extended till May so no real hurry       Car is sitting on the platforms and pretty well level all round Sent from my ELE-L09 using Tapatalk
 Re: Winter hibernation repair projectsGoing to use the string method to set up the alignment, uaed a piece of wood and a level to set the steering wheel properly but, even though its not really necessary I might move the passenger side string a bit nearer      Sent from my ELE-L09 using Tapatalk
 Re: Winter hibernation repair projectsMade up a diy plumb Bob to check the camber  Exhaust extraction for while the engine was running  Made all the adjustments to the front and rear geometry, it's very basic but will be OK as a starting point, car is declared off the road so can't drive it to the garage for a full four wheel laser alignment check, if travel restrictions are eased enough in March I might put it back on the road then. Sent from my ELE-L09 using Tapatalk
 Re: Winter hibernation repair projectsHad to review the way I laid out the strings for the alignment as I couldn't get consistent readings, used some drain pipe with slots cut exactly the same distance from each other then by measuring distances from each hub I got the strings square, also I used some fishing line instead of the strimmer cable as it was easier   Plumb line to check the camber  Much better results now Sent from my ELE-L09 using Tapatalk
  so true
   Re: Winter hibernation repair projectsSo now that I've finished the suspension bushes and alignment it's time to do something else. The second hand mohair top needed to be cleaned, I was given a Christmas present of the auto glym softop cleaner so the to make use of it  The worst of it, still not too bad   Sent from my ELE-L09 using Tapatalk
 Re: Winter hibernation repair projectsScrubbed as directed   Results aren't bad for a first attempt   Sent from my ELE-L09 using Tapatalk
 Re: Winter hibernation repair projectsNext on the list is a steering wheel cover to try to cure sweaty hands due to a worn wheel, cover supplied by Wish, purest of chinese finery  All sewn up, will be interesting to see how long it lasts  Now looks like I'll have to do something about the condition of the seats, Leather has gone pretty hard and lots of cracks, anyway, that's for another day Sent from my ELE-L09 using Tapatalk
 Re: Winter hibernation repair projectsHardtop back on for probably the first time in 4 years, 5th of April can't come soon enough    Hopefully the government will let us out to play next month Sent from my ELE-L09 using Tapatalk
 Re: Winter hibernation repair projectsPops, that looks exceptional. Well done. Great to keep track of the work. I've used that Autpglym in tyhe past. Found it excellent. Car looks great.
 Re: Winter hibernation repair projectsThanks Len, that was the first time I've used the auto glym stuff, it worked pretty well but now it seems very easy to leave finger marks on it, anyway, a couple of hours on the road and it'll be fine. Getting a bit carried away with the cleaning
 Re: Winter hibernation repair projectswow pops, great work there! Love the alignment rig and the steering wheel came out much better than the first picture would make you think
   Re: Winter hibernation repair projectsThanks Steve, next few weeks hopefully we'll be back on the road to see the benifit of the work
| Who is onlineUsers browsing this forum: No registered users and 1 guest | ||
