Postby 93 Mk1 » Tue, 28 Jun 2022 6:11 +0000
I'm considering the same regarding the charcoal cannister myself.
Postby notch000 » Wed, 29 Jun 2022 1:08 +0000
its very easy, and totally reversible too
https://www.youtube.com/watch?v=F544yP7tqdw
notch000
Postby 93 Mk1 » Thu, 30 Jun 2022 8:21 +0000
I have all that side of the engine bay stripped out at the moment. I'll probably not put it back in. I'll see how it looks anyway.
Postby notch000 » Mon, 11 Jul 2022 8:13 +0000
i fitted a cold air induction kit, I was looking at K&N typhoon ($$$) or a cobalt intake with heat shield($$). But with brexit & shipping etc decided to try the cheap route, Found this max power beauty on ebay($). I wanted to hate it but its not bad at all, slightly disappointed its maybe quieter then my old set up of a K&N panel in the original air box. Throttle response is better (placebo maybe) def no worst and it gets a bit rowdier over 5K RPM. Its probably quieter low down which is probably a good turn too. I was left disappointed it is missing the snorting induction noise I was looking for, I might double down and get a proper k&N cone to fit onto this piping. (I loved the roar of the K&N kit on my old pug GTI) The Kit is quiet well made otherwise and with no instructions supplied was only about 30mins to fit. No pictures but same as linked. The silver is a bit naff so might spray it black. Cleans up engine bay another bit too.
https://www.ebay.ie/itm/303862593216?_t ... %7Ciid%3A1
notch000
Postby notch000 » Mon, 07 Nov 2022 4:06 +0000
notch000
Postby Pops » Mon, 07 Nov 2022 4:27 +0000
That's going to the extreme altogether, when you have time, have a look at yorkshire car restorations on YouTube, absolutely shocking how bad the rust is on mk2 and 3, see if you can get the playlist
https://youtube.com/watch?v=6eQijpdj9Ns ... marE6JChQQ
Postby notch000 » Mon, 07 Nov 2022 7:01 +0000
I have, and they do great videos, I have my sill repair done, came out very well, just ready for paint, couple of patchs done ok and making a bit of work out of the battery tray yet, welding work stalled so i started undersealing again hence the power washing, il get pictures up later , failed nctcretest too but that another story
notch000
Postby Pops » Mon, 07 Nov 2022 7:06 +0000
Ha, its never ending, my civic failed because 2cm of the end of the mirror indicator lens is broken
Postby notch000 » Thu, 17 Nov 2022 9:49 +0000
Ok first real welding job done and dusted, really happy with result, it was only a bubble that the NCT guy put a finger hole thru. My first attempt was pretty rough to I cut it back further and restarted. Body work is not too difficult just very time consuming and a steep learning curve. There was also many steps of grinding, rust treatment. cutting, re-cutting, skim, prime, underseal, final coat etc. All of this is pretty invisible as not really in anyone's field of view on the lowered car sill bottom !! The aerosol colour match is good, but the texture of the undercoating where reapplied is not the same as factory and the undercoat lines is a bit sharp but who cares.
My battery tray rebuild is still a WIP and bit of a mess compared to this.
https://photos.app.goo.gl/puhFT3sjqSGerK5V6
https://photos.app.goo.gl/wFySTsQUetebGsnEA
https://photos.app.goo.gl/4pLNRQbHH6LnBY2M8
https://photos.app.goo.gl/BNC1yi8SFeU5c8Qy7
https://photos.app.goo.gl/8NYvrs3F6BA2qANM6
https://photos.app.goo.gl/9Qb4DSEQWtkMTGm5A
https://photos.app.goo.gl/3hBbMx5Z9EfDjAgNA
https://photos.app.goo.gl/JXmEeesmJDCZgBaL6
notch000
Postby Pops » Thu, 17 Nov 2022 11:27 +0000
Well done, a very good result
Postby Steve » Tue, 03 Jan 2023 11:30 +0000
wow great job!
Which mig did you get again?
Postby notch000 » Wed, 04 Jan 2023 11:53 +0000
Hi Steve, got this one, its a dinky little machine that easily moved about maybe 7-10kg. Also runs off a standard 13amp house plug.
https://www.sip-group.com/product/sip-a ... lder/05793
The gas & regulator cost about another 200 . I'm not sure yet id recommend it , i think it more focused at flux core and Im finding the wire feed a little inconsistent for finer MiG welding. Maybe just my inexperience too, I have a little bit more patching to do and il revert back again. i had looked at much more expensive equipment but pull back and though if I took to the welding id upgrade later. Its been harder to get back into then i imagined. It not too difficult just really time consuming. (which is in sort supply ATM)
no much update otherwise. I had been cleaning up the rear arches & undersealing. I was a bit more thorough on the rear end, stripped fully, epoxy primer, seam sealer, several coats of underseal afterwards. Should see me out for a few years !!
I also got delivered 1L motorsport engine mounts and full set of 1L bushes front and rear. Also got some OEM car matts, pedal rubber's and a new electric aerial to fit, plus some other random bitt i was missing. I got still at a 10% discount for black Friday but only noticed afterwards there prices went up mysteriously about 4% the eve before but a discount none the less,
I think ill go all out and do the rest of the suspension and drop the rear subframe for a clean up while I'm at it.
(drop link, ball joints, track rod ends , ARB bushes, diff mounts, shifter rebuilt etc). I ultimately want this ropy old car virgin tight !
I need to get back to finishing welding up the battery tray again first.
https://photos.app.goo.gl/68vLVMufkJtG14rX8
https://photos.app.goo.gl/WGccJ8yo7iWFnwtB7
https://photos.app.goo.gl/dbTytAYZNMj7YZ7h6
A note to oneself i might set up a full life project thread yet on this to document for myself.
notch000
Postby Steve » Fri, 06 Jan 2023 10:22 +0000
Thanks for the link and info. Yep, a thread would be great.
Nice work, I've just fitted another set of engine mounts in the last couple of weeks, very fiddly on the passenger side but doable if you remove the intake manifold support and slide it out towards the front of the engine.
Postby Pops » Mon, 09 Jan 2023 1:45 +0000
Got it reclassified as vintage / veteran, painless process and save €460 per year
Postby notch000 » Wed, 11 Jan 2023 11:43 +0000
wow great result, (only) another 6 year to go for myself. hard to believe it had it 9 yrs now.
notch000
