Getting rid of Spots
Postby robmx5 » Thu, 19 Mar 2009 9:45 +0000
Ok folks,
Have to arrange my NCT shortly - will i have to disconnect/remove my front spots in order for it to pass - any ideas ?
Robin
Re: Getting rid of Spots
Postby fabfiveferg » Thu, 19 Mar 2009 9:57 +0000
Why do you need to remove them Rob?
Postby Stig » Thu, 19 Mar 2009 10:16 +0000
You could just send her thru "as is" and see what happens? :tongue: :tongue:
Postby mx5ash » Fri, 20 Mar 2009 1:04 +0000
Unless they are wired to the headlights in some way i would say leave em connected. They won't test them i don't think. When I took mine in and i forgot to turn them off before handing over the keys. Nothing mentioned.
If you do need to remove them then easiest way wold be locate the switch and pull the wires from the back (taping them up of course) that or take out the bulbs.
Postby tigger » Fri, 20 Mar 2009 11:11 +0000
HI robin,
Ive had lots of experience with nct due to the emissions problem that i was having with my five. and i had spots that were wired up to the headlights.
The only thing they asked me to do was to put some installation tape around the wires which i should have done anyway
Other than that they never said nowt about them.
One other thing as everyone has mentioned if you have the red reflectors on your
bumper take them off or put black tape over them or them will fail you for that.
Check the rubbers on your pedals to make sure there not worn away, ummm everything should be cosure with your baby.
Hope this helps
more bounce per ounce
Davey Tiggs G ;o)
tigger
Postby robmx5 » Fri, 20 Mar 2009 10:01 +0000
Thanks lads - I just remember reading somewhere (can't remember where) that non-standard spots could be a fail on the nct - mine are not wired to the headlights - on a different switch - so can have them on without any other lights - looks good - but no sure if road legal
As Ollie suggests - think I will book it in and say nought - Cheers
Robin
Postby leamyj » Sat, 21 Mar 2009 8:39 +0000
Getting rid of spots????
Try Clearasil :mrgreen:
