by Steve » Wed, 22 Feb 2017 1:22 +0000
I was moving the MX5 this morning, its been sitting still for a few months. I started the car but couldn't get it into any gear. Turned car off, no problem getting it into gear, so it wasn't the slave or master. Ended up putting it into reverse gear and starting it with the clutch in, it jumped back initially (as I'd expected) then idled normally. Am I right in thinking that the friction disk had stuck to the flywheel due to lack of use?
- Site Admin
by MX5Spares » Wed, 22 Feb 2017 6:26 +0000
Hi Steve, common enough for disc to be stuck to flywheel or pressure plate.Be fine now.
by Steve » Wed, 22 Feb 2017 10:02 +0000
nice one. Also, my clutch pedal is engaging almost on the floor, not sure if it was always that way and I just need to get used to it again  Must bleed it anywho.
- Site Admin
by MX5Spares » Fri, 24 Feb 2017 8:14 +0000
Check fluid level and have look at slave cyl in particular for leaks.If not then master cyl.Possibly in the cabin behind the clutch pedal area/carpet etc.Bleed it if not and monitor the level etc
by Steve » Sat, 25 Feb 2017 11:02 +0000
yeah, had checked levels and all look ok plus fluid still not black. Might just swop it out while I'm at it. thanks
- Site Admin
by MX5Spares » Sat, 25 Feb 2017 5:36 +0000
Hi Steve , sometimes it hard to bleed the system but if there is still fluid in it may be ok.Fully drained they can be awkward.I have old master cyl cap which I drilled a hole and popped in car tubeless valve and now I can pressurise the system slightly with slave cyl nipple open and works a treat every time
by Steve » Sun, 26 Feb 2017 1:06 +0000
cool thanks. The Master was "bench" bled when I put it in and have a straight run clutch hose from master to slave (no pigtail bit), so am hoping it'll bleed easily enough.
- Site Admin
by MX5Spares » Sun, 26 Feb 2017 2:05 +0000
Ah ,probably will bleed easily then
by Johnny » Mon, 27 Feb 2017 12:28 +0000
Steve, where did you source that straight run clutch hose from master to slave you mention above. Reason I ask is that mine wouldn't go into gear after about a week up on ramps doing various jobs. Turned out clutch fluid reservoir was more or less empty. Checked slave and master cylinder and both seemed fine. Filled up with fluid and pumped clutch and see that its weeping from that flexible clutch hose where it joins that flat square bracket before lower steel line heads on down to the slave. Looks like a right pain to get at. Was wondering why they run the piping over and back along the firewall before going down to the slave, as both master and slave are on the same side of the car. Anyway what you mention makes sense, so was thinking of going this route if I knew what type of hose to get (length etc), fittings I might need, and where to get it. Is it same for mk2 as mk1? Sorry for kinda hijacking thread.
Johnny
by Merlot man » Mon, 27 Feb 2017 9:15 +0000
Steve wrote:cool thanks. The Master was "bench" bled when I put it in and have a straight run clutch hose from master to slave (no pigtail bit), so am hoping it'll bleed easily enough.
Ya that's the way I did mine on the mk2 I think I got the straight SS hose from a group buy on nutz but I think mx5 parts do them as well but be sure you get the hose from the master to the slave not just a SS hose to replace the existing rubber hose and keeping the pig tail Ring them if your not sure Brian
]96 na Merlot edition. sold 99 nb 10th anniversary 93 na s ltd
Merlot man
by Johnny » Mon, 27 Feb 2017 11:51 +0000
Johnny
by Steve » Tue, 28 Feb 2017 12:52 +0000
I bought mine through a group buy on here a number of years ago, but that line looks exactly the same. V.quick and easy to fit (and you can pull all the old line).
- Site Admin
by Johnny » Tue, 28 Feb 2017 1:54 +0000
Good stuff, thanks Steve.
Johnny
by Real Rayzor » Tue, 28 Feb 2017 10:05 +0000
You can get the clutch line at www.freakyparts.co.uk I was just researching it last week.
Real Rayzor
by Steve » Wed, 01 Mar 2017 10:51 +0000
some great stuff on that site, hadn't seen these before : http://www.freakyparts.co.uk/epages/es1 ... rade_Front
- Site Admin
