difference between eunos & mx5
The forum for contacting Mazda directly with queries, comments, questions & suggestions.
Postby ger » Sat, 04 Apr 2009 9:16 +0000
Can we work up a list of the parts that differ between an Irish mx5 and a jap import.
Very few as far as I can see.
1. ECU minor difference results in 118bhp vs. 115bhp for the Irish model.
2 badges/name
Anyone add to the list
Mazda keeps looking for a chassis no. and then say they have to call Japan even though you may tell them the part is common from 89-97 or 89-93 and so on.
Is there something we can do to resolve the chassis no issue for jap imports?
Ger
Re: difference between eunos & mx5
Postby Steve » Sun, 05 Apr 2009 12:35 +0000
Hey Ger,
heres a list from the old uk mailing list archives
3.Thinner windscreen, I had to buy a new seal when replacing mine.
4.Limited to 180 kph /112mph .. (before you remove the screw in the cluster ;-) )
5.No rear fog light
6.Sealed beam headlights
7.Red reflectors
8.Rear numberplate surround is square ;-)
9.Catalytic converter overheat warning light in dash
10.Hole in Cat for overheat warning sensor ;-)
11.Roadsters not fitted with a hard top were not supplied with 'Frankenstein'
bolts.
12.The side hard top mounts were not fitted to Roadsters unless a
hard top was fitted in production.
13.Fuel filler restrictor not fitted to Roadsters. Not that you'll find leaded petrol anywhere too often ;-)
14.Instrument panel warning lights on Roadsters include one for seat belt not fastened - and there's a buzzer for seat belt not fastened.
15.MX5's have a hazard flasher warning light and a 'rear fog light on' warning on the instrument panel
16.Double DIN radio was fitted to Roadsters
17.Automatic gearbox is available on Roadsters. There are a lot of specification differences with automatics - radiator, camshafts, etc are different, apart from the gearbox.
18.In 1994, a bigger (1.8 litre) engine was fitted. UK versions of this have EGR (Exhaust Gas Recirculation) fitted. Roadster versions do not.
Postby leamyj » Sun, 05 Apr 2009 9:33 +0000
Vive la difference :alien:
No mention of air-con??
Postby Steve » Sun, 05 Apr 2009 11:45 +0000
nah, aircon was an option..
Postby Stig » Sun, 05 Apr 2009 2:47 +0000
seatbelt warning light on the dash?
Postby MX5Steve » Sun, 05 Apr 2009 4:22 +0000
Yours might be dis-connected, do you have a seat belt buzzer....
The connectors are under the driving seat.
Postby ger » Sun, 05 Apr 2009 7:58 +0000
when I posed the question, I was more thinking about parts you would want to buy from Mazda. Not all the minor or cosmetic differences.
For example when I wanted a rear crank shaft oil seal Mazda seemed to be under the impression that this may be different on imports and wanted to contact Japan.
So the list I was thinking about was more along the lines of serviceable parts.
Lets say a memo to Mazda parts depts saying "all service parts common 89-93 except for..." and so on.
or a default list of Irish chassis no's according to the various models that could be used when someone calls with an import parts request.
Postby Fergus » Wed, 15 Apr 2009 10:33 +0000
Somehow, I just don't think this is gonna work out the way you want it to :roll:
Postby ger » Thu, 16 Apr 2009 9:14 +0000
I guess you are right.
Postby satfan54 » Sat, 06 Jun 2009 10:52 +0000
You were right ok. It will take 3 months for an answer from Mazda. The same time that is automatically given when you mention an import when ordering parts from them.
satfan54
Postby penelopepitstop » Sun, 07 Jun 2009 9:25 +0000
Hi Guys
Is this site no good for ordering parts? I heard you can get anything you need from here.
http://www.mx5parts.co.uk/
penelopepitstop
Postby leamyj » Sun, 07 Jun 2009 1:21 +0000
That and a few other sites,
I tend to stay clear of mazda dealers if I can help it, unless someone else can convince me to the contrary :wink:
Mazda... where's the promised interaction???
Return to Ask Mazda...
