power steering
power steering
Postby briantec » Mon, 27 Apr 2009 12:34 +0000
lads i have a 98 mk1. every now and again my power steering just goes. it doesent seem to make a difference if it hot or cold. fluid is good and most times its when im sideways :( not good
any ideas thanks
98 mk1 na8c
briantec
Re: power steering
Postby Steve » Mon, 27 Apr 2009 9:39 +0000
Sounds like your pump is pumping air rather than fluid for those moments.. fluid churned up by the pump will airate (spl?).
I'd suggest changing your fluid.. try and get Redline PS fluid its formulated to avoid the airation (seriously.. is this how its spelt?).
When draining, undo the lowest part of the return line and turn the rack fully from one side to the other to pump out the fluid in the rack.
Re: power steering
Postby briantec » Mon, 27 Apr 2009 9:56 +0000
sound. was thinking something like that. i will try it thanks
98 mk1 na8c
briantec
