Hi all,
I done some work recently to my 5 - replaced the timing belt and
replaced/flushed the coolant.
My problem is this - the coolant temp is normal at idle and up to around 100 km/h
on the road. But when I exceed 100 km/h the temp needle rises from half way
to around 3/4 mark. Sometimes even higher to not far off the red limit. The
ancilliary belts all seem tensioned correctly and I can't seem to find any air lock in
the system.
Any ideas ?
Also recently I started to feel a judder coming up through the gear stick at
certain rpm i.e. 2000 rpm in 4th gear, 3000 rpm in 5th gear.
Has any of you ever experience this ? I've only noticed this occurance ove the
last few days.
Mark.
