Clutch hyrdaulic system capacity?
Postby JPW » Fri, 09 Oct 2009 11:49 +0000
Hi. Quick question. Has anyone replaced the clutch fluid on their car? Any idea what the system's capacity is? lt doesn't seem to be listed in Rod's famous manual. l have some fluid left over from a recent brake bleed and wanted to check before l start - to make sure l don't run out!
BTW - nice to run into Kamili and Penelope Pitstop at Cars and Coffee Carrickmines last week. Hope to see you there again soon!
AKA Jeremy
Click below to check out my MX-5s in the Octane.ie garage:
Formerly 1.8 S-Special in Black
Now Cheap but Cheerful in Mariner Blue
JPW
Re: Clutch hyrdaulic system capacity?
Postby JPW » Fri, 09 Oct 2009 12:08 +0000
Just to add - why l'm doing this:
On a slow commute l find that, as the journey progresses, the clutch bite point moves closer and closer to the floor. When l next drive the car, l find it's back to normal. l'm guessing this is due to degraded fluid getting less effective as it warms up.
How does that diagnosis sound? Anything else l should be considering?
AKA Jeremy
JPW
Postby Steve » Fri, 09 Oct 2009 12:49 +0000
JPW wrote:Just to add - why l'm doing this:
Mine does the same and I assume thats the reason too (mine also needs changing). Can't remember how much it takes, but it wasn't alot AFAIR.
Postby Ivan » Fri, 09 Oct 2009 1:07 +0000
Mine did that for a good while but it was the slave cylinder that went in the end.
Postby JPW » Fri, 09 Oct 2009 1:31 +0000
l guess my theory was that the system wasn't leaking as the clutch "rights" itself once it's had a chance to cool. And l don't see any decline in the fluid level. Fingers crossed the bleed will sort it for a while.
Liking your sig by the way. Hoping to stick a rotary, a roof and a few extra doors into mine next year ;).
AKA Jeremy
JPW
