Change a front hub
Change a front hub
Postby fabfiveferg » Wed, 11 Nov 2009 10:17 +0000
Left front wheel bearing is knackered. I have a second hand hub to replace it but was wondering do I need a special tool to remove/ replace it?
Re: Change a front hub
Postby fabfiveferg » Thu, 12 Nov 2009 9:57 +0000
Anyone???? Bueller???
Postby Stig » Thu, 12 Nov 2009 10:07 +0000
I'll check my maintenance work book and post later.......K :wink:
Postby Stig » Thu, 12 Nov 2009 10:16 +0000
Ok, it says - take the centre dust cap off, and with that out of the way, set about slackening the hub nut. This is staked into a groove in the stub axle and you need to straighten out the staked area so the nut can be turned. When this is removed, you'll find that the hub will be extremely tight as its torqued on.
29mm fits the nut (unusual size, check you have first) Book says a 1 1/8in AF socket will work too.
You need a good long length of bar to crank it off using the law off the lever etc.
HTh's
Postby Steve » Thu, 12 Nov 2009 10:20 +0000
nothing unusual apart from a 29mm socket..
remove wheel, caliper, caliper bracket, brake disk, 29mm nut on the hub under the hub cover (you'll need some scaffolding/cheater bar), remove hub.
Postby fabfiveferg » Thu, 12 Nov 2009 10:32 +0000
You guys Rock! Thanks for that.
Postby Stig » Thu, 12 Nov 2009 10:41 +0000
Try and crank off that nut whilst the car wheel is on the ground as that nut will give resistance.
Postby fabfiveferg » Thu, 12 Nov 2009 10:45 +0000
Yeah I've been touting for a fat mate as well :wink:
